Question about Zanussi Dryers
Zanussi TC485W condenser tumble drier trips fuse when switched on
  • 859 Answers
If your dryer has been fine for sometime and then failed you probably need tech service for a replacement element or motor. Or should you feel qualified, run down the power to your drier including your ground. Your ground wire should NOT be connected to a water pipe. It must be directly connected to your main circuit panel. Then do this. Check for a high load on your motor. If you don't have any then it is shorted in the wiring. That are all the major working parts to your dryer or any dryer. The timers wouldn't cause this.
When a dryer element is carrying a proper load the circuit physics are correct, when the burn out it acts like a direct short and will pop your breaker or will not dry at all. The same is true for your motor. The wiring inside the motor can overheat and the varnish on the wiring wrappings can melt and short.
Posted on Jun 15, 2008
  • 243 Answers
I had the same problem when I moved into my new house and upgraded the dryer. Its most likely the ground wire. Best to get a multimeter and test everything. If your not able to do that. You should call an electrician and have him check the wiring. Where he may need to run a new ground to your fuse box.
  • 2 more comments
  • Nathan Ayers
    Nathan Ayers Jun 15, 2008
    In these models of dryers its likely to happen more being that there condenser style. Which means the drying circuit is starting up and trying to build the energy it needs. It then ends up tripping the fuse if its not grounded properly. Thats in the period where it makes a humming noise before it starts. This can be cause by the outlet itself just needing to be rewired and checked to make sure its good. Or as it was in my case a whole new ground wire was needed cause the wiring was too old.
    hopes this helps answer your problem, Thanks -Nate
  • Nathan Ayers
    Step 1. Make sure It has power.
    Step 2. Check to make sure the motor doesn't move. Or that other things
    do or dont work, Make Sure the fault is not with the timer line switch or the
    door lock switch.
    Step 3. Check the power to the speed control board (pins 3, 4 and 5) is good.
    Step 4. Make sure the voltages for the powerboard on pins 2, 4, and 8 are 120VAC as required. The
    voltage on pin 1 and 3 will be the same as pin 10. If you were to put a small load on it, it
    would be the required zero volts. if not unit is bad
    Step 5. Check and make sure the fuse is good.
    Step 6. Make sure resistances between pins 1 and 2, 2 and 3, 1 and 3 of the speed control board are 3 Mohms +/- as required.
    Step 7. Check to ensure Motor winding resistances are OK.
    this should help you get on to fixing it.
    THANKS, Nate
  • Nathan Ayers
    Most of the steps I listed above can be done with a mulitmeter. If you find you are unable to do it. Its best to get a technician out to help you service the unit. Give you a idea maybe of it needs something replace and if its worth it, or if its better to replace the unit itself.
    But it sounds to me that if you just put it in and its having the problem. its the ground wire. But you can perform everything I said to test the unit itself.
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    let me know if you need anymore help with any of the tips ive given you. Should you choose to do it yourself. If Not Thank You and its been a pleasure assisting you, Nate
    as always thanks for using FixYa
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Our Zanussi condenser dryer, trips the house circuit breaker, at change of tumbling direction
I myself would say you have a bad Motor.Something in that motor is not working correctly.
Nov 20, 2010 | Zanussi TC7102W Electric Dryer
Drier spinning but doesn't get hot/warm.
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Sep 03, 2010 | Zanussi TC7102W Electric Dryer
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
Why does my tumble drier not get warm?
you could be looking at several problems
1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough!
2 it could be the water collection pump? Can you her it running?
3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Jul 20, 2010 | Zanussi ZWF1420W Front Load Washer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Dryer trips the fuse box
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
140 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
