Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
Posted on Nov 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the cleaning cycle? - Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Anonymous
Level 3:
  • Jenn-Air Master 43,501 Answers
  • Posted on Nov 07, 2010
Anonymous
Jenn-Air Master
Level 3:
Answers
43501
Questions
0
Helped
10837561
Points
101584
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
1helpful
How to set the self clening feature on a very dirty oven
If you have a manual locking mechanism right above the oven door, make sure it is fully engaged or it will not go into cleaning cycle. Most of the time, as long as you pull out the oven racks, you should be able to select the cleaning cycle and hit start. some models might even ask how long of a cleaning cycle. most of them are automatically set for 3 hours of clean time. Unit will get very hot during cleaning cycle.
1helpful
How to clean my jen air built in oven
For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
I hope this helps.
Code "door" when setting CLEAN cycle.
if it is OPEN IT IS RIGHT IF IT IS CLOSE IT IS WRONG
1helpful
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 • Ovens
1helpful
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
1helpful
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
2helpful
2answers
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 • Ovens
5helpful
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
1helpful
2answers
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 • Ovens
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
