Question about Hampton Bay 24750 Huntington III Ceiling Fan
Extension pole sways back and forth while the fan is on
  • 20 Answers
One or more blades is out of line. Get a ruler or a stick and mark the distance from the tip of one blade to the ceiling. Hold the stick in place and carefully rotate the fan until the next blade is near the stick. Do this until you have all four marks on the stick. It is important to try not to alter the position of the extension pole in between blades. Now you will find that one or more blades are at different heights. Carefully bend the worst blade until it is closer to the rest. If teh blade holders are cast, this may not be possible and you may have to pack the blade angle with washers or cardboard until they are right.
If by some chance they are all close, then it may be the "attack angle" of one blade. This is harder tot detect but sometime you can pick which balde by eye and adjust by trial and error until it is better.
Cheers,
Glenn.
Posted on Nov 07, 2010
Grinding noise front end left side at highway speeds and when turning wheel back and forth at high way speeds
Sounds like front wheel bearings.
Does the sound go away when swaying one way or the other?
If you way left and ot gets louder it should be the right bearing and opposite for swaying right
Jun 12, 2012 | 2004 Ford Explorer
I need to know the name of the two short bars on the back side of the axel that keeps the van from swaying back and forth
sway bar links or stabilizer links? One end is attached to the stabilizer bar and the other end is attached to the strut I believe.
Nov 03, 2010 | 1999 Chevrolet Venture
Misassembled black 18" Holmes stand fan with remote (HSF1809R)
Hello cdelune. Glad to see you fixed the problem but Im having the exact same issue with the fan! Not sure what to do with the pole with the frayed ends and how to connect it with the plastic falanges. Ive been at it a while now so do you think you could help me out and post exactly what you did to fix it? Thanks.
Jul 25, 2010 | Holmes Products Dryers
Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
My truck is swaying back and forth. It does not
replace right & left rear upper & lower track rods see it all the time
Jan 17, 2010 | 2001 Nissan Pathfinder
Suspension?
have the sway bar looked at in the back. if it is loose or broken it will sway. it is the bar connecting the two rear wheels. there are upgrade kits that offer a heavier bar. Also check rear tire pressure. the tires will roll out if too low a pressure is aboard.
Jul 01, 2009 | 2000 Jeep Grand Cherokee
Rocking and rolling back and forth
i would check the bushings in the sway bar or the sway bar itself, either way, have fun buddy
Jun 16, 2009 | 1996 Chevrolet Blazer
Rear of 2001 Vette sways back & forth on the highway
vettes have independent rear susp. have the car looked at by reputable shop sounds like it needs alignment if camber or other settings are off this would cause the sway
Jul 21, 2008 | Chevrolet Corvette Cars & Trucks
Hampton Bay 24750 Huntington III Ceiling Fan Logo
212 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
