Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
I was told to bypass the thermostat by shorting the two connector wires. The fireplace lit so I replaced the thermostat with another two wire milliamp thermostat unit.Fireplace worked for about three weeks then stopped. Then it would only light with the two wires connected. Now does not light period. Is there anyway that I can troubleshoot this problem using a volt/ohm meter?
  • 5 Answers
SOURCE: fireplace clicks and shuts off when running
There are a few things that could be causing this problem. The most common resolution to this problem is making sure the thermo couple is screwed tight into the valve. While looking at the gas control valve, you'll see a few wires and small metal tubes going into it. The one you want to tighten is the tube that is copper. Even if you get only a half a turn on the little brass fitting that's holding it screwed in, that's usually enough. If that doesn't do the trick let me know and I'll get back to you with some other things to try.
Posted on Jan 26, 2009
  • 5 Answers
SOURCE: Montego gas fireplace
There is a product that I use when servicing gas fireplaces that works pretty good. Google search "Rutland White Off". In a lot of cases it takes just about everything off and the glass looks brand new. If it went to long without being cleaned, it could be permanently baked into the glass. As far as removing the glass, every manufacturer uses there own style of clip. Check around the bottom of the fireplace where the controls are for a latch or possibly screws that are holding it in place, sorry, without looking at it, it's pretty hard to answer that part of your question
  • 5 Answers
SOURCE: black soot on glass and black smoke comes out
In order to change or "convert" your Natural Gas fireplace to Propane there are several parts that need to be changed. First you need a part called an oriface. There is one for each burner (you may or may not have more than one) and one for the pilot. There may also be a pressure regulator somewhere in the pilot system. Some fireplace units require the entire burner and or pilot assembly to be changed. You also have to change the pressure regulator on the main gas valve, once again your unit may require you to change the entire valve. The fireplace manufacturer or the store where the fireplace was purchased will have to tell you what the parts are. This is a pretty technical process. If you do not get the pressures correct in the conversion your sooting problem will continue. Depending on your skill level you may want to call a fireplace professional. But be sure he/she knows what they are doing. Some service people can't get a conversion right.
Posted on Apr 29, 2009
  • 139 Answers
SOURCE: How do I install a gas fireplace intact/flue?
you cant. a clearance of 3 inches must be maintained to combustibles where you penetrate the roof.you shouldn't be overly concerned about this small area.
Posted on Sep 19, 2009
  • 81 Answers
SOURCE: fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Posted on Dec 02, 2009
FIREPLACE WILL NOT TURN ON
Yes and no......
If the fireplace wont turn on from that switch, Most likley a diffrent switch
Dec 19, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
What thermostat will work for my gas fireplace?modelwh060396b 07/2006 has remote want a wall mount
A search for that model number did not yield any results. A brand name would help.
That said, if your gas fireplace has a milivolt valve with "TH" and "TP/TH" terminals on the side (for hooking up a remote, thermostat, or switch), then you can use a universal wireless wall system.
You can find wireless wall systems for gas fireplaces HERE.
Dec 23, 2012 | Heating & Cooling
I have the honeywell round thermostat #, CT87K. I am trying to wire it up to controla gas fireplace. I have two wires coming from the fireplace I have tried every combination of wires. it will turn the...
That Thermostat will not work on a gas fireplace. The voltage is all wrong. You need a thermostat that will work on millivolts generated by the thermopile on the pilot assembly of the fireplace burner. It will only turn on, because you opened the circuit. It will not turn it off automatically or at all, for that matter.
Better yet, why don't you purchase a Wireless Remote Control that has a thermostat built-in. It's a multifunction remote that will work up to 25 feet from the fireplace and comes with a wall hanger. The SkyTech # 3301TH, should work well for you. http://www.skytechsystem.com/
Feb 17, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
The heater does not shut off until I flip the breaker.I have replaced the thermostat.It did not fix the problem.I was told it was because I used a cheap thermostat.Then I was told the thermostat had...
try this. open the front of your furnace and look for the thermostat wires. i' dont know what you have but anywhere from 2 to 6 wires in something like a phone wire .find the termial board and take the red wire off. then close the furnace back up making sure the doors are on correctly.did this stop the frunace from running? if so you have a short in the thermostat wiring. check it to see where it is shorted out .replace the red wire and away you go.
Feb 02, 2011 | Honeywell TH4210D1005 Heater
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
Electrical Short in Printed Circuit Board.
Hi, do you know what these wires were for? You can bypass the board, but if the wires are for lets say the blower motor and you bypass and put them to direct hot legs, you will run all the time, or what ever shorted the block in the first place must have a short. Its probably in the wires at this block and if you apply it to 120 volts it may fry again. I would follow these wires back to see what they run first. Yes, it can be done.
Shastalaker7
Jun 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Pilot is lit but the heater won't fire up
A few things dictate when the main burner turns on. One is a thermocouple not getting hot enough, the other is a bad thermostat ot thermostat wire, and another is the gas valve. First look at the gas valve located on the heater and make sure it is in the On position and not in the Pilot position. Remove your thermostat and jump the two wires together. The heater should light. If not, go back to the gas valve and find the wires up to the thermostat, the should be attached to terminals marked TH and MV or something similar. Jump the terminals. The heater should start. If not, you may need to replace the thermocouple.
Sep 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Sunbeam electric fireplace
Most likely sounds like the thermal fuse has gone out. if you take off the top of the fireplace you will find a little metal tube in front of the blower. This is the thermal fuse if it has gone out only your fan will blow and the heating element will not put out heat. You can pick one of the fuses up at radio shack for 3 dollars. the only problem is how to go about repacing it since it was crimped in and you can't use a soldering iron because it will trip it. If I come up with a way to change it I will let you know so far I can't.
Dec 11, 2007 | Ovens
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
189 people viewed this question
Top Napoleon Pool & Spa Experts
Paul Carew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
