Question about Admiral 32 cu. ft. Washer
Was making a loud noise while on spin cycle. then stared smelling a burning smell and it shut off and won't wrk
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Admiral Expert
  • 154 Answers
HAS BAD TRANSMISSION OR BAD WATER PUMP
Posted on Nov 08, 2010
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 04, 2013 | GE Dryers
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have a maytag washing machine model A712, during the spin cycle there was loud screeching noises and burning smell. What could be the problem.
problem could be the gearcase or the motor, to find out remove the motor and turn it with your hands to hear any abnormal sounds coming out, and also try to smell the motor see if it has a burning smell
Oct 16, 2011 | Washing Machines
The washer makes a loud noise when it spins and there is a burning smell.
sounds like bearing may be going out shut down call repairman if the smell,smells like rubber its the belt
Nov 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Admiral 32 cu. ft. Washer Logo
209 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
