Question about Acer Aspire 5630 Notebook
Is there a bios battery in the Aspire 5630 a where is it
3 Suggested Answers
sim4182
  • 393 Answers
SOURCE: bios password I need? acer
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Posted on Oct 14, 2010
joecoolvette
  • 5660 Answers
SOURCE: How to clear and load cmos default bios parameter
Two methods;
A)
1) Remove ALL power to the laptop, except the CMOS battery.
Remove the AC adapter (Charger) and Battery.
2) Press the Power On button in, and hold it in for a full count of FIVE seconds.
Let go of the Power On button.
Do this procedure TWO more times. (Important)
This procedure clears CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
Reinstall power. Install the Battery FIRST, then the AC adapter.
B)
Go into BIOS Setup.
As soon as you press the Power On button, start tapping in 2 second intervals, on three keys at the SAME TIME.
Press all 3 keys at the same time.
CTRL, ALT, and ESC.
No?
Hold the Power On button down for 10 seconds to turn the laptop off.
Wait 30 seconds, turn the laptop back on.
As soon as you press the Power On button start tapping on the F2 key.
(Tap in 2 second intervals)
When in BIOS Setup look at the main page, and towards the bottom.
Here you will see an F key listed that when pressed, will revert BIOS Setup back to the factory default settings. (Generally F6)
C) Remove all power from the laptop.
Lay a towel on a table, and lay the laptop upside down on the towel.
Open the Memory Compartment Panel, and remove all ram memory modules. ('Stick')
Located towards the middle of the ram memory compartment is the J3 jumper.
There is a J3 with a square line going around it.
This jumper is used to clear any settings made, and will go straight back to all factory default settings.
In otherwords if someone set a BIOS password, the J3 jumper will remove it.
Factory setting for BIOS password is no password.
Regards,
joecoolvette
Posted on Oct 09, 2011
Battery does not charge to my Acer Aspire 5738-6969
There is a known issue with the BIOS bug in some of the Acer model that it prevents charging. Trying upgrading the BIOS from Acer online to the latest version following the online instructions.
Sep 27, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I bought a new acer aspire 5630 laptp battery but it is not working when fits into, whereas when I put it on the old battery it works on the power as the old battery is fully exhausted. Someone told me to...
What I believe they were mentioning is Flash the BIOS to the most current version, which should on the Acer support site (Support.acer.com or such)
If the old battery wasn't charging and the new one doesn't either then there also may be a hardware issue with the charging circuit if the BIOS flash doesn't resolve, at which time you discuss that issue with Acer if under warranty.
Jun 23, 2011 | Acer Aspire 5630 Notebook
Im currently using the acer aspire 5630 series and i turned it on and its asking for a setup up password. Do not know what that means or what to do. Help please??
1.I thing you set the password for bios,So then only you got like that.
2.So diasble the bios password otherwise fomate your hard disk
3.Otherwise rest you CMOS battery.
Nov 18, 2010 | Acer Aspire 5630 Notebook
Bios password I need? acer aspire 5630
Sep 21, 2010 | Acer Aspire 5630 Notebook
Bios password
to get rid of passwords in bios, removing the small computer battery that keeps the time on your computer will work. only sometimes though
Apr 30, 2010 | Acer Aspire One PC Notebook
Anyone know how to unlock a locked bios on an Acer 5630? My wife forgot the password and now I can't log on. my newphew locked my acer how do i unlock it he changed the password and doesnt remember it
Reset the Bios by removing the small battery inside your laptop in few seconds. but you need to open your laptop if this under warranty don't open it to avoid broke the warranty bring your laptop to warranty if they ask you the payment for removing the password just pay them.. the inportant is the warranty still there.., if not under warranty open you laptop remove the battery or short it in few second to remove the Bios password.. if not Bios password. use the program password changer or password remover,, just donwload in ISOHUNT.COM program is available there..< program name> hirens, password changer...
May 26, 2009 | Acer Aspire 5630 Notebook
Problem
is anyone know about this? i changhe video driver,(removed), change bios into latest versnion, but still disame problem.
Oct 04, 2008 | Acer Aspire 5630 Notebook
BIOS Date and time not advancing
I experience that already, system date /time is loosing, You need to replace the cmos battery and set the time in the bios setup.
I guess there no other fault except the cmos battery busted.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 14, 2008 | Acer Aspire 5630 Notebook
Acer 5630
That's weird. can you check that you have the proper timezone settings under "date/time settings" and that your system is not automatically syncing itself through the "Internet Time" tab?
Oct 29, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
