Question about GE GSD5130 Dishwasher
How do I find and fix the problem of one and one half inches of water left in the bottom is the dishwasher when the cycles are completed?
    President:
  • 1,140 Answers
Firstly, check to make sure the waste outlet from the dishwasher isn't blocked. Remove, the drain hose where it attaches to your sink and check both the hose and the sink inlet connection. If these are clear, make sure you sink is draining efficiently and, if your are using a disposer make sure this is clear as well.
If the waste hose and outlet checks out, turn the dishwasher power on, and open the door. At the bottom of the wash compartment, on the front left side is the float. Lift the float as high as it will go and see if the washer pumps out.
Try these tests first and post back with the results.
Regards,
BElectric
Posted on Nov 07, 2010
Why is my dishwasher leaking soap foam from the lower left area of the door?
A leaking dishwasher can be caused by excessive soapsuds. Excessive soapsuds are the most common reason dishwashers leak. Excessive soapsuds will cause dishwashers to leak from the door. Good dishwasher detergent will have no more than half inch of suds on top of the water. So any time your dishwasher is leaking from the door open the door, if there is more than a half inch of suds your problem is in your soap. One drop of hand soap, hand dish washing soap, or any other soap will cause dishwashers to leak. Now, I am not suggesting that you intentionally put this soap in the dishwasher because if you did the soapsuds would be from top-to-bottom of your dishwasher. Now if there are a lot of suds you can fix it by pouring vinegar or cold water into the dishwasher and running it, this will kill the subs.
Jul 08, 2013 | Computers & Internet
The dishes are not getting cleaned completely also I have notice some soap left at the end of the cycle.I tried to remove the bottom spin blade and top.Looks like it is too tight.Is it attached with...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 10, 2011 | Maytag MDB7100AWB Dishwasher
After running a cycle there is still abount 1 inch of water left in bottom of dishwasher. What can it be and how can I fix it?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 15, 2010 | KitchenAid Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
After using my dishwasher,there is water left at
check all filters inside the dishwasher something is blocking the outlet hole,but also remember all dishwashers have about 1 inch of water left after a wash so check between washes.adrian;;;
Jan 20, 2010 | Dishwashers
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
My dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
GE GSD5130 Dishwasher Logo
85 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
