Question about Turbo Air 72 cu. ft. / 2039 liter Commercial Freezer TSF-72SD / TSR-72SD
Leaking H2O I have a turboair delux model TSR-72SD three door fridge and a large puddle has accumulated under it. any ideas?
    Guru:
  • 1,524 Answers
Behind the grille on the bottom is a drain pan. May have a crack in it.
Posted on May 28, 2009
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Fridge stays at 28
Is it a fridge or freezer, and what are the symptoms, in detail? Is all working normally, just not switching off? Check condenser clear and clean, and try turning thermostat down to 1 (if mechanical) or up to 40 (if electronic)
Apr 26, 2014 | Turbo Air 72 cu. ft. / 2039 liter...
The left hand door is energized and shocks people when they open it. My understanding is that there are wires in the door, which power a heater. Is this heater necessary? Can the power to the door be...
Yes. The heater is there to prevent condensation. If you disconnect it you may get moisture on the glass. If you cut the wires be sure to tape them up.
Jan 29, 2011 | Turbo Air 72 cu. ft. / 2039 liter...
Constant Defrost causing water accumulation problems
Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
Good luck and be careful.
Dec 29, 2009 | Whirlpool Freezers
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freeze will not run doors heat nothing else
That is known as a puffed capacitor and usually indicates a power supply problem as well. The cap can be changed with a 50/50% chance to work again unless it took out other components.
Sep 14, 2007 | Turbo Air 72 cu. ft. / 2039 liter...
Turbo Air 72 cu. ft. / 2039 liter Commercial Freezer TSF-72SD / TSR-72SD Logo
104 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
