Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The light bulb on my opener is off when it should be on. If I screw the bulb in or out slightly, it turns on and flickers a bit. When the timer times out, the light goes out. If something crosses the sensor or the door is opened or closed again, the light doesn't come one unless I screw it it in or out again. It has been like this for years! Thanks in advance for any help. -- In the dark
    President:
  • 3,197 Answers
Unplug the opener and remove the bulb. Use a small screwdriver to pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Posted on Nov 08, 2010
How to change brake light bulb on a 2014 fiat 500L
https://www.fiatusa.com/download/pdf/manuals/2014-FIAT-500L-OM-1st.pdf
it's in your owners manual page 358 chapter 7
you need a torx 20 screwdriver or bit
Rear Tail, Stop, Backup And Turn Signal Lamps
1. Open the liftgate.
2. Remove the two screws and remove the tail lamp assembly.
3. Remove the four screws (using a T20 driver) and separate the backplate from the lamp housing.
4. Remove the tail, stop, or turn signal bulbs by pushing them slightly and turning counter-clockwise.
5. Remove the backup lamp bulb by pulling straight out.
6. Replace lamps as required and reinstall lamp.
Center High-Mounted Stop Lamp (CHMSL)
This light is an LED assembly. See your authorized stealership
Mar 30, 2015 | Fiat Cars & Trucks
Tip
BMW 650 Tail Light Problem
If you find that your BMW 650 CS/GS/Dakar tail light doesn’t work at all or flickers when riding, chances are the metal power terminals inside the bulb socket are no longer making a good connection with the metal bumps on the tail light bulb. This is a very common problem with the BMW 650 of all makes, models, and years. Fortunately, there is a very easy fix.
Due to excessive vibration, temperature changes, and replacing light bulbs, the two metal power terminal tabs inside the tail light socket deform and get pushed too far back inside the tail light chassis. This prevents the tail light bulb from making good contact with the power terminals and the smallest vibrations can cause the electric connection to break temporarily or indefinitely.
To fix the problem, all you need to do is pry the two metal power tabs forward just a little so that they make a better connection with the metal bumps on the tail light bulb. If you look at the back of the bike, the red tail light casing on the 650 CS/GS/Dakar is held in place with two screws. If you remove these screws the red tail light casing comes off and you have access to the light bulb inside. At this point, turn the ignition on, but you don’t need to start the bike. Remove the light bulb by pushing in and twisting clockwise about 1/8 turn. If the bulb flickered while removing it, then the bent power terminals are most likely the cause.
Looking at the tail light bulb you should see two metal bumps. These bumps need to make a good connection with the two metal power terminals inside the tail light casing. Turn the ignition off and find a small tool that you can use to pry the power terminals forward just a bit. Make sure the bike is off and you don’t want the power terminals tabs inside the tail light casing to touch.
After you have made the adjustment, turn the ignition back to “on” and re-insert the taillight bulb. If the bulb is lit, then you are done. If it still flickers a bit and doesn’t stay lit, then you will need to continue prying the tabs forward until a good connection is made.
on Dec 18, 2009 | BMW 650 Cars & Trucks
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need a good vacation timer. Any suggestions?
Copy following link to see analog vacation timers that turn lights on at random times.
Set current time slightly different so lights inside house can turn on-off at slightly different schedules.
Rotate dial to set current time, plug timer into outlet, make sure bulb is good, turn light ON, and plug light into timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#vacation
Multi-function digital timers, such as Woods 59377, and lifetime-warranty Intermatic DT620 also have vacation feature, and timers have 2 outlets, but programming is more complicated than using analog timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Jul 13, 2012 | Hardware & Accessories
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
Garage doors work but the light on one of the inside opener keeps flickering, What do I do?
disconnect the power and try to pry the prong in the socket of the light outwords,check the connection in the unit itself
Jun 11, 2011 | liftmaster Chamberlain Garage Door Opener...
How to change front turn signal light bulb 1992 cadillac deville
You need a T-15 star bit driver that is referred to as TORX. On the top and bottom of tail light are the screws. Carefully remove the chrome trim then the light pulls out after applying slight upward pressure. Once you twist out the socket the bulb simply unplugs. It should be either a 3057 or 3157 bulb.
Dec 20, 2010 | 1992 Cadillac DeVille
Problem with light on unit
Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely.
Sep 29, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
97 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
