Question about Pride New Mobility Victory XL 4 Wheel Scooter
Could you please tell me where i will get forward& reverse throttle for pride victory
  • 280 Answers
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Posted on Nov 07, 2010
Pride xl victory slipping drive in reverse ok forward graham
Check the brake assembly to see if it is operating correctly
May 09, 2017 | Pride Health & Beauty
I have a Victory three electric scooter and it will not go forwards but does go in reverse just fine. Could you tell me what and how to check it to find the problem?
Hi , if the scooter goes into reverse okay , it could a be throttle issue , or the forward logic( mosfet out put ) of the PG Drives controller has failed...
I offer free testing if based you're in the UK...
Regards
www.gewizrepairs.co.uk
Jan 20, 2015 | Pride Mobility Products Pride Victory 10 -...
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
Apr 24, 2014 | Pride Mobility Products Pride Mobility...
From willaston auto electrics adelaide , customer brouht in a pride pathfinder 4 wheeler no forward or reverse movement, has power to volt gauge, horn works, any suggestions appreciated
neville the problem could be numerous things but lets try the simple ones first. a bad throttle pot or speed control pot can cause that problem. Both of those are located in the tiller console and that has to be removed to test them. You can ohms check both with power off and you can voltage check them with power on. You should get a smoth change in resistance as you turn th speed pot and as you move the throttle forward and reverse with power off. alsdo chech the connections in the tiller and remove the seat and battery cover and check the connections at the rear of the scooter sometimes just moving the wires can get it moving again but that won't help you locate the problem if you can't isolate the bad connection or bad wire. Scooters are tough to repair because of the many connectors that they have and the cables runnig front to rear that can cause problems especially with Pride scooters Good Luck I know I didn't give you much but I'm not fond of working on scooters Hope this Helps
Oct 12, 2010 | Pride Mobility Products Victory 9 Scooter...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Oct 04, 2009 | Pride Mobility Victory 3 Wheel Electric...
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Start & stop , Kind of willy nilly.
hi, it could be the speed pot or wig wam as it called , try moving it at a angle to see whether it goes okay
Jun 30, 2009 | Pride Mobility Products Go-Go Elite...
Pride New Mobility Victory XL 4 Wheel Scooter Logo
473 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Colin Taylor
Marvin
Marvin
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
