Hi
It all started with a small leak that stopped the dishwasher from working, We changed the large rubber ring in the outlet and also changed the rubbers in the door
Now when the water comes into to dishwasher it doesn't stop and then it starts to overflow, maybe we have not put it together properly
Your help would be much appreciated
Kind regards Christine
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
candy cd623. water left in bottom of dishwasher after cycle, does not drain.dishes are clean. workrd...
(More)
candy cd623. water left in bottom of dishwasher after cycle, does not drain.dishes are clean. workrd fine before i got it from a friend
A candy cd623 that iv'e aquired causes the power to trip. This did not happen instantly but about...
(More)
A candy cd623 that iv'e aquired causes the power to trip. This did not happen instantly but about 15secs after I plugged it in.(did'nt even switch on)This was after I disconected the heater.Any ideas? thanks martin
