Question about Cisco Aironet 1130 AG 802.11a/b/g Wireless Access Point
What is the default level_15 id /password for the Cisco Aironet 1130AG?(I tried cisco/cisco)
5 Suggested Answers
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
SOURCE: Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Posted on Mar 12, 2009
SOURCE: how to reset to factory default a Cisco Aironet
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Posted on Apr 18, 2009
    • 30 Answers
    SOURCE: How can I change the default management vlan (vlan
    create a new vlan (eg vlan 10)
    then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
    do the same for the wireless port
    then shut down vlan 1
    Posted on Dec 05, 2009
    Can get router to work
    The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
    This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
    A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
    This resetting process works through your internet browser.
    Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
    Enter your user and password information from the pop up menu.
    Click on the "Setup" button from the summary status page.
    Select the "Cisco Services" setup option and click on "Manage System Configuration."
    Click on "Reset All System Factory Defaults" to reset the router.
    The Cisco Aironet 1200 will be restored to factory defaults.
    http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
    Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
    May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
    Not accessible
    There should be a reset button on the back, did you reset it?
    Jul 30, 2013 | Cisco Aironet Air-ap1131ag-e-k9 1130ag...
    Reset cisco aironet 350 adapter
    Try Putty and a 9pin male to RJ45 RS232 serial console cable.
    the instructions are in the link provided here:
    http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
    Jun 30, 2017 | Computers & Internet
    How to login to cisco aironet 1130ag access point
    Hi Harris, please see link below, it has quick startup guide for you
    http://www.cisco.com/en/US/docs/wireless/access_point/1130/quick/guide/ap1130qs.html#wp37913
    May 31, 2011 | Cisco Aironet 1130 AG 802.11a/b/g Wireless...
    Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
    Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
    Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
    Reset cisco airnet 1130ag
    There are 2 ways to reset the access point.
    Using the MODE Button
    Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
    1. blank.gifOpen the access point cover
    2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
    3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
    4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
    5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
    Using the Web Browser Interface
    Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
    1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
    2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
    3. blank.gifEnter the username Cisco in the User Name field.
    4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
    5. blank.gifClick System Software. The System Software screen appears.
    6. blank.gifClick System Configuration. The System Configuration screen appears.
    7. blank.gifClick the Reset to Defaults button.
    Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
    8. blank.gifAfter the access point reboots, you must reconfigure it.
    Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
    Default username & password after hard reset
    Username:[none]
    Password:Cisco or
    :root
    :Cisco or
    :Cisco
    :Cisco
    Try from above 3 then you can access cisco router.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
    Nortel phone 2210 not working with Cisco AP 1231
    Reason: Previous authentication no longer valid
    This suggetss it has the wrong password or the wrong authenticaiton type (WEP vs WPA, for example)
    Jan 23, 2009 | Cisco IOS
    Jan 15, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
    Cisco Aironet 1130 AG 802.11a/b/g Wireless Access Point Logo
    554 people viewed this question
    Top Cisco Computers & Internet Experts
    Gopi Venkatesan
    Gopi Venkatesan
    Prashant M
    Prashant M
    Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
