Question about D-Link AirPlus DI-524 Wireless Router
I tried hooking up the internet through a d link 524 router and it doesn't seem to be working. I've done the cable things, power cycled the modem and the router, but to no avail. I've even followed the isp's installation instructions. Not sure what else I can do.
  • D-Link Master
  • 7,733 Answers
I have no connection to the internet going through the wireless or the wired portion of my d-link DI-524 router ,I only have a local connection . Is this repairable or is the router FRIED and needs to be...
try rebooting your cable modem by unplugging it then after 15 seconds plug it back in. let it come up, then reboot your router and wait til it comes up. If it still doesn't connect then there may be an issue with the router. I'm guessing the cable modem is OK since you were able to post here. I was going to tell you to hard wire your computer to the cable modem as well.
Jul 22, 2011 | D-Link AirPlus DI-524 Wireless Router
D-Link Router, Model DI-524 is not able to register IP address. My cable company did maintenance yesterday and this morning unable to link to internet with Router hooked up to modem. Apparently no good...
Sometimes when ISP's do maintenance the DHCP servers re-assign new IP numbers. When you have symptoms like yours it's because the modem, router, and computer are working off previously assigned old IP numbers that may have then been re-assigned to other customers modems after the maintenance. Same with the router. Rebooting your equipment causes them to pull new IP numbers and things start working again.
So, usually a reboot will fix it. Turn off the computer(s). Turn off or unplug the power cables from both the modem and the router. Keep them off for 3 or 4 minutes. Leave the data cables connected. Plug the power to the modem back in FIRST. Give it a few minutes to come up. Any lights should be green. If the lights don't come up green on the modem you'll need to call the cable company.
Second, plug in the router and let it come up. Again, lights should be green. Lastly, turn on the computer.
That should do it. If not, please post back. There are other things to try.
Jan 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Hello, the 4 LAN ports on my D-Link router, model DIR-615, don't seem to be working. The lights are not coming on. This is the 1st time I'm trying to use those LAN ports so that I can connect my new...
It probably is your router that is the problem.
Disconnect its AC power, and reconnect it, to "reset" the router.
Also, try connecting your Blu-Ray player directly to your cable-modem (or DSL-modem), bypassing your router. Turn the modem off, and then turn on, and then turn your Blu-Ray player on, and it should be able to connect to the Internet (and NetFlix).
Try a different router.
Oct 17, 2010 | D-Link AirPlus DI-524 Wireless Router
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
My computer connects with my wireless router but no internet info passes through. the internet works when i plug directly from the cable modem.
power cycle your modem and your router and shut down the pc. before plugging router back in, hold reset button down for 1 min. plug all back in and start pc up. should have connection.
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
No internet through router
** Try this steps
- Check physical connection (Modem=WAN Port, Computer=Port1) *should be hard wired connected*
- Power cycle modem and router for 2 minutes (to turn off the modem and router)
- Check web browser for Internet connectivity
* If nothing happen reset the router for 15 seconds and try the steps again.
Feb 14, 2009 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
Have to keep depowering, repowering router
The best thing to do here is to update the firmware of the router to resolve this problem, so you don;t need to always power cycle the router.........
Jul 29, 2008 | D-Link DI 514 Wireless Router (DI-514)
Cannot connect to internet through DI-524
After you've rebooted your wireless router...make sure you reboot the cable-company (or DSL) modem while the router is connected to it and on. The modem seems to recognize the router properly only in this way.
Simply unplug the power to the cable-modem and plug it in again.
If the cable-modem has a battery back-up you'll want to remove that as well.
Feb 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
23 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
