Question about Samsung AW1203B Air Conditioner
Samsung air conditioner
Unit is less than 1 yr old, and this summer it does not get as cold as before, and the low speed does not work -- only med. High seems the same as med.
    Novelist:
    Champion:
  • 230 Answers
What kind of air conditioner is this? Samsung makes a lot of different styles and applications. A model name could help too.
In the meantime I suggest that you read the maintenance procedures for cleaning the unit and give that a shot. Many problems are solved or avoided by simply cleaning and maintaining your equipment.
Posted on Jun 16, 2008
Fan will not run without starting it yourself and will not run high speed at all
Sounds like an old unit with a bad run capacitor or
check the components on the board for burnt wiring.
Fans on window units are controlled by a 3way switch. High, Med., and low. Your power and in most cases a capacitor which doubles for the compressor and fan.
So it can only be 1 of the 3
Burnt out windings on the motor
Bad switch
Bad capacitor
May 01, 2014 | Haier HWR06XC7 Air Conditioner
Where do the 3 wires from the blower motor connect to on the control board for high speed use in the summer time? Black, Blue, and the Red one? The white is a no brainer. I can go to M1, cool, and heat....
Hello, the black wire is your high sped motor tap and it should be on cool as you have it. Blue is med-hi and red is your low speed motor tap. You have it wired correctly. Now the freezing can be caused by 2 things, low airflow or a low refrigerant charge. Low airflow can be caused by a dirty air filter, dirty evaporator coil, dirty blower wheel or the blower itself is running slow due to a weak capacitor. Anytime the motor is changed out the capacitor should aswell. If the airflow appears to be ok then the unit is low on refrigerant.
Jul 11, 2012 | Heating & Cooling
CEILING FAN w/remote. It worked until removed to paint. When it was reinstalled the speed is backwards (high for low, no med, low for high) & lights do not work. The re installer is not an electrician,...
There should be a small switch or a cord (tied to a switch) that changed the direction of flow. The reason for that is because you want the fan to move air downward CCW in the summer and upward CW in the winter.
Aug 11, 2011 | Heating & Cooling
Put in new central air unit, water blowing directly off the a coil into the duct work
Hello, sounds like the blower speed is set to high, try lowering it to med high or med low to see if it helps.
Aug 03, 2011 | Heating & Cooling
Blower stays in low...
That will be in the lower motor,the speeds,so to fix the speeds,the motor will have to be replaced.
Jul 24, 2010 | Kenmore 70187 Air Conditioner
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Blower motor for electric furnace
yes you can as long as the temperature rise is whithin the proper range in heating on you unit data plate there should be the information the you need to have.
Jan 11, 2009 | Heating & Cooling
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Samsung AW1203B Air Conditioner Logo
124 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
