Question about Maytag Washing Machines
I have a 3 year old Maytag MAV208DAWW. It went unbalanced on a big awkward load and we didn't catch it until it had moved across the floor and was pulling at the water hoses. I moved it back into position and releveled it but now it sometimes goes unbalanced even with light loads that are evenly distributed. What are possible problems and how can I check them out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
CHECK LEGS MAKE SURE LEVEL
Posted on Nov 08, 2010
  • restorat Dec 13, 2010
    I releveled it after it went unbalanced the first time but it still goes unbalanced VERY easily. I've also noticed that the drum is often not centered when I open the lid after the spin cycle. If I remember correctly it didn't used to be like that.
Maytag fabric matic washer started walking across floor on spin cycle?
Usually an unbalanced load, but check if rubber feet are worn through.
Jan 03, 2015 | Maytag Washing Machines
During spin its unbalanced
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 12, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
SPINS BUT SOAK CLOTHES
The solution was given earlier.Thank you
Feb 11, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
The washer gets unbalanced on small loads that never happaned before a couple of weeks ago. The machine has a unbalance spin load compensator but makes ungodly banging now, that's never happen until...
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Mar 08, 2011 | Maytag MAV5920E Top Load Washer
My front load washer "walks across the tile floor", it is level, what can I do
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Load starts banging like it is unbalanced
Check first the machine balance, to ensure the machine is at level and well balanced and that is not the problem.
If you already inspected springs and strut, then the problem is usually the drum bearing, or the drum bearing spider that has broken.
You can superficially check if there is a problem with the drum bearing by spinning the drum with the hand to check if there is excessive play.
If you found oil under the machine, check also that the support for the motor and motor gear box under the bearing is not damaged, and any of this part is banging again the chassis, this can cause oil leak, and machine shaking.
The most common is a bad bearing.
Mar 27, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
