Question about DCS 36-6-1 Gas Kitchen Range
I HAVE THE MIDDLE SECTION OF MY TOP MIDDLE BURNERS THAT DO NOT IGNIGTE WHEN I TURN ON THE BURNER. THESE PILOTS STAY ON AND AREN'T ELECTONIC.
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
We just bought an older house with a jenn air cook top but the pilots are out. How do we light them?
First, you need to look below the cooktop to find the gasline. There is supposed to be a shutoff valve on this gasline. Turn the handle so it is parallel with the gasline (perpendicular is closed) to open it. Before lighting anything, smell around high and low around the cooktop and make sure you do not smell any gas. You can also spray soapy water on all the gasline fittings to detect leaks by looking for bubbles that form. If all is safe, using a long butane lighter, light the pilots for the cooktop. There should be 1 pilot for every 2 burners. You will probably have to remove the grates and metal spill covers to light the pilots. The pilot should be approx 3/8" tall or less. Test each burner individually to make sure they light off the pilot. If they do not, you may need to clean the vertical holes on the side of the burner (where the lighting tunnel connects) by poking them clean with a needle. If the horizontal burner holes are clogged, clean them as well. If there is also a built-in wall gas oven, be sure to light that pilot on that as well. Good luck. Douglas
Sep 28, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Can't get burners lit.
    1. make sure the gas is turned on.
    2. Make sure unit is pluged in.
    3 make sure all burner and burner caps are aligned.
    If you hear a spark and you small gas it should light.
    Make sure the burner heads are not clogged.
    If this top has pilot lights make sure the pilots are lit
    Nov 23, 2008 | Cooktops
    How do I turn my oven on!
    The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
    Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
    DCS 36-6-1 Gas Kitchen Range Logo
    26 people viewed this question
    Top DCS Kitchen Ranges Experts
    John Tripp
    John Tripp
    Paul Carew
    Sal DeAngelo
    Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
