Question about Garmin StreetPilot C330 GPS Receiver
My screen calibration is off -- if I type a 4 I might get a 1 -- or an 8 might be a 5 --- this is causing a lot of mis-typing issues. Is there a way to recalibrate the screen?
  • Garmin Master
  • 587 Answers
I'm not so sure how to do your unit but on the Garmins Tools.... Help section has the troubleshooting area that is awesome, look for it on your unit
I'm not sure on this either but check your keyboard see what language its in....
to do that go to Where To..... Address....spell city.....on bottom of screen press MODE
make sure American English is picked
Posted on Nov 07, 2010
How do I find the calibration panel which has vanished from the control panel settings
Request you to try following the below steps which might help:
    (1)Click start.
    (2)Type services.msc in the search box and select the same.
    (3)The services screen appears and detect Human Interface Device.
    (4)Right click on it, select properties, select start up type as automatic and then start the service.
    (5)Now restart the computer. Now check if calibration panel gets detected.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Sep 25, 2014 | Dell LATITUDE Computers & Internet
Why position fault code 14.113 for atamaxI4308?
Good Day
Position faults are usually caused due to either a dirty or uncalibrated media sensor.
Make sure the correct sensor type is selected under MENU MODE / MEDIA SETTINGS / SENSOR TYPE.
Media sensor is usually green in color, on top will be a white line or arrow indicating where the sensor is located. Inspect the gap between the upper and lower pieces of the sensor to see if there is any dirt buildup or pieces of labels stuck inside, try cleaning the gap with isopropyl alcohol. In case there are labels stuck and you cant get it out, you will have to remove the sensor and take it apart. Just be careful when doing so as the plastic can break very easily.
What you also can try is to re-calibrate the media sensor, switch the printer off, hold down the feed button while switching it back on and booted up until it starts feeding the labels.
You can also do a Manual calibration through MENU MODE / MEDIA SETTINGS / SENSOR CALIBRATION and select STANDARD CALIBRATION and follow the on screen prompts.
Hope this helps, good luck.
Sep 03, 2014 | Datamax I4308 PRINTER 4 Inch DIRECT...
Touch screen not calibrated correctly. Keeps typing "M" when trying to back space
have you stuck any screen guard on the screen of you cellphone
if yes
then remove it and try typing backspace it really work
if no then contact customer service point
Feb 06, 2013 | Samsung Rugby SGH-a837 Cell Phone
I have a Garmin Nuvi 1450 that I bough in December 2010. This morning, when i try to type in an address, the touch screen is behaving erratic. For example, when N is pressed, it types M. Erase is not...
nuvis do not have a calibration screens or settings, to fix your issue try updating the units firmware with Garmins WebUpdater software this could fix your issue, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 13, 2011 | Garmin nuvi 1450 GPS Receiver
What would cause my engine to hesitate when in motion?
A bad plug, If the car is sitting at idle it doesn't require a lot to keep the plugs firing, so when you drive the spark increases more frequent and one of the plugs may not be able to fire on every stroke at the best it should causing a mis-fire. If you change these, use a OEM type because some of these platinum and higher rated plugs will make a 4 or 6 cylinder runs worse. I've seen this happen quiet often.
Sep 09, 2010 | 1994 Nissan Pickup
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Samsung L200
Sounds like your lens has been mis-aligned, if a lens on these types of cameras is jolted or knocked around it will mis-align the lens or take it out of calibration. The best thing to does is take it to a camera shop and have them look at it
May 08, 2009 | Samsung L200 Digital Camera
Text in excel textbox turns to gibberish
It may be a font issue... did you change the font of the typed-in text to a non-True Type face? For every typeface there are two fonts: a screen font to display on your monitor and a printer font for printing,
If somehow there is confusion or corruption in the Excel file contents about exactly which font is specified at a given point in the text box (e.g.if you type like I do with lots of backspaces, which are actually special codes that can cause such corruption), then the misfire between screen and print fonts can cause the text data to be corrupt. It seems to be an operating system issue (did you make a lot of changes to fonts on your system?) or something wrong with your personal installation of Office 2003 in any case, because Excel 2003 is a very stable release. To fix this I would try examining the Windows\Fonts folder using a third-party tool or comparing its contents to a known-good Windows installation (or simply copy and paste your typed paragraphs into Notepad and re-paste it into a new text box in a New Document (starting fresh with a new Excel worksheet could solve it all by itself).
Apr 13, 2009 | Microsoft Excel 2003 (065-03992) for PC
Leapster screen
Sounds like it needs to calibrated - see http://gobaco.wordpress.com/2006/10/31/how-to-calibrate-the-leapster-handheld/
for info,
Feb 19, 2008 | Video Game Consoles & Games
Unable to enter address as keyboard types a letter other than the one selected
press and hold the power button for approx 30 seconds. a calibration screen will appear. perform touch calibration to correct.
Nov 03, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
