Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
My default IP ADRESS is192.168.1.1, and am trying to change my router password for wireless connection
  • U.S. Robotics Master
  • 7,733 Answers
If you ever lose your settings or if your settings are changed and the router is not functioning properly, you can come to this area to restore your saved settings from the backup file you created. Click Browse to locate the backup settings file you previously created. When you have located it, click Restore and the settings saved within this file will be applied to the router. If you did not create a backup file, you may need to restore the factory default settings.
my default  IP ADRESS is192.168.1.1, and am trying - device3.gif Factory Settings If you ever want to erase all personal settings of your router, come to this area and click Reload to restore the factory default settings. All the current settings will be lost. If you change the router's configuration and it stops functioning properly you can reload the factory settings to fix it.
device3.gif The other method to restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds. You will lose all of your personal settings if you restore the factory default settings. You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
Posted on Nov 08, 2010
2 Suggested Answers
  • 192 Answers
SOURCE: cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Posted on Jan 04, 2009
I need internet on my dsi
Well, have you done the homework?
1. DSI needs WiFi, ie, wireless internet. Do you have a wireless router or wireless modem router in your place?
2. If yes, have you enabled the wireless radio in the router. This can be done by opening up the router options by typing the IP Address of the router (it should be somewhere written in the router itself) and login. If you don't know the password, google your model number and you will get all information like default ip address, login etc. If possible download the manual from the manufacturer website and go through it to familiarize the options. (If you have an apple router, you will need "airport utility"..google).
3. Once logged in as "admin", look for "wireless" options (Manual will help you), enable "radio", "ssid", note down the ssid name, and for troubleshooting purposes, leave the security "off/disabled". Save/apply changes.
4. Make sure wireless "G" is selected or a mode thats compatible with wireless "G" (go through the options, mostly default option will suffice). If this is in another page, again, save or apply changes.
5. Reboot the router, wait for a couple of minutes till the lights for internet and wireless appears.
6. From DSI, search for available networks, find the ssid name that you have noted down and click connect.
7. Hopefully, it should connect, otherwise, you may have to manually enter DSI IP Adress, subnet mask (255.255.255.0), gateway and dns servers (both router IP Adress). If your router address is, say 192.168.1.1, then give dsi an ip adress 192.168.1.xx where xx is a number between 2 and 255. That is, what ever ur router ip address is, just change the last digits to anything under 255, excluding the router address. Now try again, hopefully everything should be settled.
8. Look into DSI manual to see whether it supports wpa/wpa2 security or just WEP. You may also have to take into consideration any other devices that connect to router wirelessy, like laptops, smart phones, tablets etc. If all of them supports wpa/wpa2, go back to router options and select that security, create password, write it down. Otherwise select "WEP" encrryption. (The point to remember here is the lowest common denominator, ie, if DSI supports only WEP, selecting WPA/WPA2 will be useless, as DSI will not connect, even if it sees the SSID.
9. Save changes, reboot router, wait for lights to steady.
10. From DSI, again select your SSID name from available networks (just to make things easier, shut down DSI, restart to disconnect earlier connections), it will ask for password or both password and security type. If DSi supports WPA/WPA2, and ur security is set as such, and DSI is not connecting, play with the options, if any, like "WPA only", WPA2 only" WPA/WPA2" and try to connect.
You should succeed with this much details. Good luck
Jan 15, 2012 | Nintendo DSi Matte Blue Console
Adress is 192.168.1.254 iwhant ueser and password
type in a browser your IP address (192.168.1.254) a window should pop up asking for your credentials, Unless you have changed them they should be:
user: admin
password: (blank)
this is the default password for this router. If you have changed it (and forgotten it) , you can do a reset using a paper clip on the back of the unit. Note it will reset all settings back to the default setting.
Oct 04, 2011 | D-Link AirPlus DI-524 Wireless Router
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I change my old fios router for a new one my computer work but not my laptop. cant seems to find the password to reset
If you have manual of the router, read what's the default IP adress for accessing router. You can also try typing the 192.168.1.1 instead of a web adress in your WORKING COMPUTER'S web browser (this is the default IP usually). You will get window with username and password (you will find username and password in the manual of the router). When you access router, you can turn Wireless LAN on/off and change all values you need. You really should read manual first, it will all be clear to you after that.
May 21, 2011 | HP Pavilion dv6000z Notebook
MY IP ADRESS IS 62.171.198.11 BUT I NEED MY WPA2 KEY CAN U TELL ME IT
To connect to the DIR-655, by default, you have to enter in 192.168.0.1 in your web browser's search bar. When prompted for a username and password, the user is "admin" and there isn't a password. This can all be changed in the setup but by default, there isn't a password.
Once connected, we are greeted with the config screen. From here, we can setup our wireless networks as we see fit. There should be a wireless security tab that will allow you to change your WPA2 key.
Mar 22, 2011 | D-Link DIR-655 Wireless Router
How do i find my wpa2 key for this router? i have tried typing in th ip adress on my adress bar and it wont let me access the page.
What IP address were you entering in your web browser? Were you prompted for a username and password, or was the browser simply timing out when attempting to make a connection? I believe the default IP address for the router is 192.168.0.1 so make sure you're entering http://192.168.0.1 in your browser. If you're then prompted for a username and password then enter 'admin' for the username and try and leave the blank field blank then click 'OK' and see if you're able to login, unless you've changed this information.
Mar 01, 2011 | D-Link DGL-4500 Wireless Router
How do i hook up a d link wireless router? I don't have the manual.
Go on line to the manufacturer there should be an option on the home page for support and drivers. Click there, and you should be able to download everything you need to install your router.
Feb 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have an ibm r40. cannot connect to my wireless router.was working perfectly prior. when i hard wire to the wireless router the ststus show an ip address of 0.0.0.0
if you can set up your connection manually change the IP adress to 192.168.1.1 (this is usually the default IP adress for most routers) let me know if this helps I have more Ideas for you if it doesnt
Nov 15, 2009 | IBM ThinkPad R40 2681
Need to change netgear router rp614 from dsl to cable
Hello
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Feb 07, 2009 | NetGear WGR614 Wireless Router
Cannot access belkin 54g wireless modem settings
Jan 03, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
1,340 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
