Question about RCA F36689 36" TV
I have a 36'' RCA Guide Plus Gold TV. I connected my XBox 360 to it, but cannot figure out how to program a channel for it to come up on, or even what channel to have it come up on.
  • 1 more comment
  • James Allen Nov 07, 2010
    only has one area for input, red, yellow and white connectors. tried to scroll through the channels for which different ones were assigned and nothing.
    How do I do that?
  • James Allen Nov 08, 2010
    I figured it out, thanks for your help!
    Genius:
  • 1,340 Answers
It most likely will be found using the input button.You probably have it hooked up with yellow,red,and white RCA jacks?Turn the system on and cycle through the inputs.You should see it.If you don't,let me know and we'll figure it out. Good luck,Greg
Posted on Nov 08, 2010
  • 4,889 Answers
Through which input did you connect it on? Component? If yes then just scroll through your television's input modes(component1, component2 etc.,) until you see an image. If problem persists, then let me know and I will help you resolve it.
Sai.
Posted on Nov 07, 2010
  • eagle338
    eagle338 Nov 07, 2010
    Ok, if it has only one component input, then you should set the tv to component input mode. Scrolling through the channels will not help.
  • eagle338
    To the left of the 0, there is a button that says "input". Press it till you see component at the top. That should do the trick. If problem persists, then let me know.
    Sai.
Menu keeps popping up
If you have the guide plus feature go into the setup for it and when it asks if you have a cable box, indicate no, when it asks if you have a Vcr also indicate no. Last if it asks for the zip code enter all 9, This should rule the Guide feature out of service and you will know if it is your problem or not---it created a lot of problems in sets that had it, especially RCA or GE sets.
Dec 20, 2012 | RCA F36650 36" TV
Why does my rca guide plus gold gemstar tv have lines or bars flickering on the screen ?
are they horizontal or diagonal? if they are diagonal it could be you're brightness is turned up too high. try turning it down.
Aug 13, 2012 | RCA F36705 36" TV
32" RCA Entertainment Series, Guide
Probably not. RCA parts for this model are very difficult to find. Even you could find a kit, it will not have enough to repair. A do it yourselfer or TV tech will have a difficult time repairing this. Please shop for a new TV. Thanks for asking and show a few hands of support!
Mar 21, 2011 | RCA Televison & Video
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
Guide Plus Gold service on a 2000 Zenith TV
I have an RCA televison with Guide Plus Gold and it works great. I am not sure about the Zenith and how it works on it. When I turn on the TV with the remote the guide comes up on screen. I just have to press the guide button on the remote to remove that screen and watch the show. If I don't press anything it will go off after 2 minutes. If you have never set up the guide it will probably show up all the time. You will have to go through and program it so it will know if you have cable, over the air or satelite. I don't have satelite service so I don't know if it will reconize it. I know it works with over the air and cable.
Good luck
Nov 03, 2007 | Televison & Video
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Guide plus+ gold
use the editor in the guide to turn off and on and correct channel numbers. that should do it..!!
Apr 13, 2007 | RCA G36705 36" TV
RCA F36689 36" TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
