Question about Culligan Under Sink Water Filter
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Posted on May 18, 2011
Ro filters going bad in 60 days
IF THE RO OR ANY T33 FILTER HAS BEEN INSTALLED HORIZONTALLY, TRY TO INSTALL IT VERTICALLY WHERE THE OUTPUT IS ON TOP. GOD BLESS.
Jan 29, 2012 | General Electric Profile Smartwater Ultra...
My reverse osmosis system causes my Grunfos pump to cycle on and off for two hours aftr drawing a gallon of water from the reverse osmosis. Is there way to fix this so that the pump doesn-t cyle on an
HI THIER MR.STEELE. MY NAME CANDY A..I COULD TOTALY UNDERSTAND WHEN SAY THAT THE CYCLING OF YOUR PUMP TURNING ON &N OFF CAN GET VERY ANNOYING.LET ME ASK U A QUESTION.? HAS THIS CONSTENT CYCLING CAUSE YOUR POWER BILL TO INCREASE? OK NOW ,LETS SEE WHAT WE CAN DO TO FIX THIS PROBLEM OF YOURS..THE ITEM THAT TELLS YOUR PUMP WHEN TO COME ON. HAS TO HAVE SOME KIND OF SETTINGS ADJUSTMENT.ON IT WHAT U HAVE TO DO IS.SPREAD 4 IT TOO COME ON WHEN U WANT IT TOO.
Dec 23, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Where can I get a manual for Culligan Aqua Cleer?
I found the manual for an Aqua Clear AC15 at the following web site. Go to the below web site and locate the filters for your system. There will be a link to the manual in a .pdf format.
http://www.freshwatersystems.com/s-69-culligan-water-filters.aspx
May 15, 2010 | Culligan Under Sink Water Filter
I own the Wher25 Reverse Osmosis system. I
There is a blue cap on the body of the white pressurized water tank. Twisting off the blue cap, you will see a air nozzle - similar as those on the tire. You need to pressurized the tank to 60 PSI. I spend hours to figure out this solution on my own system.
Mar 14, 2010 | Home
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Culliagan aqua-cleer drinking water sytem: under sink install
Refer to the below link for the h-30 installation manual.
http://www.freshwatersystems.com/t-manuals.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Mar 08, 2009 | Culligan Under Sink Water Filter
Culligan Under Sink Water Filter Logo
339 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
