Question about Black & Decker Kitchen Appliances - Others
My Breadmaker which I have had a long time (B1630/B1640) has started making loud "clangin noises". Is this just age? or can it be fixed it has made great bread.
    Genius:
  • Black & Decker Master
  • 1,280 Answers
If you have had it a long time, and gotten alot of use out of it then I would just go to ebay and get a lightly used one there as it would cost you more to repair it than it would be worth and you would still have a very used machine. Ebay has deals on almost new to new machines for good prices, you might want to check those out befor making a decision.
Posted on Nov 08, 2010
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why is my regal kitchen Pro breadmaker making loud noise when kneeding the dough?
Is the dough too dry? Try adding a few Tbls spoons of water. and make sure blades and pan are set right.
Oct 13, 2014 | Kitchen Appliances - Others
Starting problem
That is the shutdown circuit on the set indicating a failure--depends on brand, model and age of set as to if it is worth fixing.
May 26, 2012 | Televison & Video
6583 makes loud noise when its turned on
My first guess is there is something caught in the pickup wheel.
1. remove the belt cover to access the pickup wheel
2. remove strings and hair around the ends
3. if you can, remove the belt and see if the noise goes away when you turn it on, this will help to isolate the problem
How old is the unit?
Does it pick up dirt good?
Describe the sound, clicking, rubbing, wheezing, bangin' or clangin'
Feb 29, 2012 | Bissell 6594 PowerForce Bagless Upright...
I require a manual for a Black & Decker all-in-one deluxe automatic breadmaker. B1640 type 1
Was not able to locate manual for the B1640; perhaps the manual for the following will be sufficiently similar to be of assistance.
B1630
http://useandcaremanuals.com/pdf/B163063.pdf
B1650
http://useandcaremanuals.com/pdf/B165064.pdf
Mar 22, 2011 | Microwave Ovens
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Kitchen Appliances - Others Logo
236 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
nanisacan
Level 1 Expert
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
