Question about HP Compaq Presario C304NR Notebook
No power Tried to log on - was notified that battery power was low and to change batter or switch to outlet. Took the battery out and plugged in adapter. Still would not turn on. Do you know if a new battery or adapter is needed or is there a different problem? I don't want to invest in either of these if it won't solve the problem. thanks. Sharon
  • SBristow Jun 18, 2008
    I appreciated the quick response and suggestions. I took the laptop to Best Buy as suggested and they told me there was a problem with the internal adapter and was directed to a repair shop.
    Thanks much. I would use your site again and recommend it to others.
  • 3,940 Answers
It the notification occurred while the AC adapter was connected to the system, then I'd suspect the AC adapter 1st.
If available, try another compatible ac adapter and see if the system powers on.
Since the system will not power on with AC adapter alone, I suspect it has failed.
Places Like Best Buy, should have a bench AC adapter you could test to see if the system powers on, if so, then buy a replacement.
If under warranty, contact HP tech support.
Posted on Jun 15, 2008
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Hello I have the 6270 touch screen keypad, however when I tried to armed (clicked into security/then select either AWAY, STAY or NIGHT) nothing happen I just heard a click and that it, do not arm, and...
sounds like the system battery may be low. The system batter is usually located , depending on the system, in the main box in a closet. The system battery powers the system in the event of a power outage.
May 13, 2017 | Ademco 6270 Graphic Touchscreen Touch...
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
My acer netbook suddenly went into hibernate while i was using it. how do i fix this?
hold the power button for 10 seconds, till it switch of, or u can yust turn it upside down remov e the batter, and the power outlet, and make push the power while the battery is out, then plug it in again and start it up
Nov 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
You should change to battery or switch to power outlet
This is typically caused by software that manages an uninterrupable power supply (aka UPS). Simply put, this is a battery that the server plugs into to so the server can run for a short time when there is a power outage.
UPS devices frequently come with software to communicate with the server so it knows when it is on battery. When the server is notified that it is on battery it will provide warning messages like the one you described. Some will even pass the notice to all computers connected to the server to make sure no work is lost.
One of the most popular programs is APC PowerChute. I would look for this program or other programs that have the words "UPS" and/or "power" in their name to find the cause.
I hope this helps.
Jun 25, 2009 | IBM eserver xSeries 205 8480
Wifi switching off automatically in mc9090
plug a car charger or mains charger into it and get power back to it before the battery gets low :D
Apr 18, 2009 | Zebra Symbol Technologies MC909X-G Series...
No power to wii
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Apr 11, 2009 | Nintendo Wii Console
Attempting to load but suddenly shut off..
It sounds like the laptop was in a screen off state (happens when it is left on but not used for a while).  When you pushed the power button it went to shutdown, and notified you that someone (you) is still logged on.  Any unsaved work could be lost, hence the warning.
Five minutes later when you went to switch it back on, the laptop coincidently must be low on battery, to the point where it will not stay on, and exhibits the problem you are experiencing now.  Try plugging in to power and make sure that the battery is charging, and try again.
Nov 06, 2008 | EliteGroup ECS A535 Notebook
Turn off by itself
Yes, you can buy new charger/batterys in PC World really cheaply and theres a Sale on now beacause its just after Cristmas so try there.
Dec 24, 2007 | Panasonic Toughbook CF-27 Notebook
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
HP Compaq Presario C304NR Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
