Question about Westinghouse Refrigerators
I have Westinghouse fridge Model--RJ390M. It is leaking water under the veg basket. I think it has blocked drain. How can I access the drain to unblock?
SOURCE: ice build up
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Posted on Mar 23, 2009
ngfam1
  • 639 Answers
SOURCE: Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Posted on Sep 04, 2008
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
  • 111 Answers
SOURCE: WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Posted on Dec 20, 2008
rpbuice
  • 161 Answers
SOURCE: we have a westinghouse freestyle
You will have to remove the freezer shelves and Icemaker then you should see the screws which hold the back panel in place. Remove these screws and you should be able to remove the back panel.
Posted on Dec 25, 2008
Why is my Kelvinator 400 twin air no frost fridge leaking water under veg compartment
Good morning Barbara, from what you are describing it sounds like the evaporator drain is clogged. You need to empty the freezer and remove any access panels to get to the drain. Get a bowl of hot water and a turkey baster,then use the baster to force the water into the drain to clear the blockage. Not real familiar with that model,so check under the vegetable compartment to see if the drain is under it first. Hope that helps.
Jan 03, 2018 | Kelvinator Refrigerators
Westinghouse refrigerator leaking , dripping water and accumulates near bottom at fruit n veg basket. Some time it also forms ice layer on glass of basket. Any solution?
You have a clogged defrost drain tube, beneath the freezer evaporator (remove the back wall of the freezer compartment) there is a drip tray with a hole in it, the hole leads to the defrost drain tube- take a turkey baster and flush the drain with warm water until you hear it pour into the pan beneath the machine... Help Me Find My Model Number
Dec 11, 2016 | Westinghouse Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
I have a Samsung srs585hdis side by side fridge and there is quite a lot of water leaking from a cover behind the bottom veg baskets. What would cause this?
The evaporator condensate collection pan drain inside the fresh food section is clogged or blocked with ice. You will need to take the cover off to clean out the drain. Here is a link that shows the breakdown of parts for the fresh food section=> HERE
Here is a link to=> Leaking Refrigerators
This video only applies only because it shows examples of what is happening to your refrigerator
APPLIANCE 911
Dec 21, 2015 | Samsung Refrigerators
Why my fridge is leaking water under the vegetables tray ?
at the back of the veg tray there should be a small drain hole , it may be blocked
Aug 27, 2014 | Refrigerators
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Fridge collecting water inside
The drain is clogged.
If you want to DIY then here it goes:
Some models have access to the drain by an elbow on the outside back of the Ref. Disconnect the drain line here and if you find the clog, great. If there is no visible drain line and elbow on the outside then...
Hopefully you can access the drain in the back top center of the fridge. This will require removing plastic covers, usually a few screws is all you have to deal with. You must get everything removed so you can see the drain hole in the back wall then you can use a tube and a little air pressure to clear the drain from that point down. If this is clear and you don't find any cloggs from that point down then the clog is at the top of the drain which is in the freezer.
This is going to require a little more work.
1. Take everything out of the freezer, put it in a cooler or just pile it in the sink.
2. Take the icemaker out.
3. Take out the back panel so you can see the cooling coils.
4. The drain hole is in the center directly under these coils but may not be visible because of ice in the drain pan.
5. Use a hair dryer to melt this ice and clear the drain so water flows down.
Dec 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Refrigerators
Refrigerators Logo
406 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Sal De
Jose Pino
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
