Question about Polaroid FLM-2601 Television
Same problem just want to know where to buy the caps and where they are located on tv
I bought my parts from MCMelectronics.com , part number
31-7465 , As long as you arent blind anyone can look at the old part and tell which way the new parts go in , In other words , Line up the NEG side of the cap,side with stipe to the mark on the pcb , Takes longer to get the TV apart than it does to change the 2 caps,All I used was a pin point soldering iron and needed to modify the outer housing or could've left it off
Posted on Aug 30, 2008
    Sergeant:
  • 280 Answers
If you don't have real good soldering skill I would advise you don't try it. they are hard to change and have to be put in in a particular direction "polarity" one wrong thing and you will smoke the board. But if you try ... any electronic parts supply has the caps ie Radio Shack
Posted on Jul 10, 2008
Cap location on ln32a330 Samsung lcd tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2014 | Samsung LN32A330 32 in. LCD TV
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
About how much does replacing bad DC Filter Caps cost? I'm wondering if it will be worth fixing it or just going out to buy a new tv? Olevia LT-42HVi 42 in.
The capcitors parts are dead on the power supply board wright?That the board,where the power a/c cord plug into it.The easy way,just go on the websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 11, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv won't power on
Could be the power board or the main board. You will know because its the capacitors that are most likely the cause. Vizio used the cheapest capacitor maker CAPXON, but to me its CRAPXON. The capacitors will have bulges on the top, and in some situations you will see they cracked open on the top. The capacitor degrades, creates hydrogen gas that escapes thru the top of the caps, which is good because it would explode if the hydrogen gas can't escape.
Cheapest solution is replace the bad caps with Japan or USA caps. They go for 50 cents a piece at electronics suppliers. Don't buy a used board because they too will have these bad caps and you will end up with the same problem down the road.
I learned my lesson, I fixed mine but I replaced only the bulge top caps, but there were about 60 more caps in my TV and they were all **** XON. Next time I am saving up to buy a SONY.
Aug 02, 2010 | Vizio VP322 32 in. Plasma TV
Tv automatically shuts off after being on for a few seconds EWL20S5
The most common problem for this set that will cause shutdown after a few seconds is the inverter board. Looking at the set from the back, it is the long slim board that is normally located on the far left side of most lcd tv's. There are 3 electrolytic capacitors located on this board, and changing them will fix a lot of these sets for this problem. The location numbers of the caps are c330, c350, and c370. If you have any experience working on electronics, I would start by changing these caps. They are very inexpensive. If you would rather just change the inverter board, try shopjimmy.com. That is a good place to buy boards for flat screen tvs.
Jul 29, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
My Polaroid FLM-2601 will power on to the point where the logo splashes on the screen and then displays the input video source. Immediately following this, the screen flickers rapidly and the speakers...
U have to replaced the whole power board,because the cap that install backward,it cause ur power ICS regulator are dead.U can't buy those ICS,because the tvs compannies only sale thesse ICS only to their sub contractors.
Mar 16, 2010 | Polaroid FLM-2601 Television
TV WILL NOT POWER UP IT ONLY DISPLAYS 10 BLINKS
I fixed three of these TV's, one a few days ago.
All three sets had two bad capacitors.
The caps are on the main board towards the front of the set, on the left side.
One cap is 2200uf 16v, and is located inside of a "U" shaped heatsink. The other cap is 330UF 16V, and is outside of the heatsink, to the left of the heatsink. Both caps will look bulged on the top. You can probably get these caps at radio shack for a few dollars. I buy my parts from Mouser electronics.
If you can see that the caps are visually bad, then replacing them will probably fix the set.
Good luck,
Dan
Oct 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scott LCD won't turn on with remote or with on button
Do not shut off the TV. Put cardboard in front of screen when not watching.
MY THEORY
The power serge when the TV is turned on puts a stress on the caps (ac to dc volts) .
Continued off -on weakens the caps until failure.
Dec 22, 2008 | Soyo DYLT032D 32 in. LCD Television
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Polaroid FLM-2601 Television Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
