Question about JVC Audio Players & Recorders
JVC CD portable system RC-X270/X260 us/u Problem: Won't record casette tapes, but will play them. When attempting to record over a recorded tape, it simply erases the tape. CD, tuner both work fine.
  • 1 more comment
  • Geddes Jun 15, 2008
    Tried both Tuner and CD. Neither resulted in a recording on the cassette.
    It worked for two years. Do the wires come loose or somehow get disconnected? I can try resoldering if you think that really is the problem.
  • Anonymous Mar 25, 2014
    how to record vinyl records, cassette tapes?
    Guru:
  • 859 Answers
Sorry to tell you that these players are famous for coming out of the factory with wire leads broken from their mounts.
You will have to dig into the guts of your player and find the loose wiring and resolder it in place.
If you don't feel qualified to do this perhaps you know a friend or neighbor that can. Lacking that a repair shop will fix it for you. But, you have to decide if the cost of repair outweighs the cost of replacing your portable player.
Sorry to bear this bad news to you.
Regards,
Worldvet
Posted on Jun 15, 2008
  • Glenn Rogers
    Glenn Rogers Jun 15, 2008
    This is a situation where it works or doesn't. The mechanical function is fine as it erases the tape, but is not actually, it is not receiving a signal to record. So, in the 'erasing' it is actually recording no signal at all. Therefore the wiring is broken off by your regular use and poor soldering at the factory. You will find this loose wire on th e board or at the record head.
    Regards,
    Worldvet
  • 1,879 Answers
When you're recording, what is the source ? CD ?
My daughter cannot record her voice onto a blank cassette tape in the cassette deck - what do you suggest? She hears nothing when she plays it back. That siad, I can't see a mic. Please can you...
Has the unit got a built in mic? Some have ,some havn`t. Some times you have to set the volume for recording.If it`s not set high enough you`ll get no playback!
Aug 25, 2012 | JVC RC-BX30 Cassette/CD Boombox
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Play back poor now Camcorder does not record
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
Nov 12, 2010 | JVC GR-DX77E Mini DV Digital Camcorder
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
I have a JVC RC-ST1, I'm trying to record from CD
check to make sure the tab on the cassette is not on, as if it is, it will prevent the record button from being pushed down , thus avoiding overwriting the cassette.
If thats not the case then the record mechanism is damaged inside the cassette caddy.
May 19, 2010 | JVC RC-ST1 Cassette/CD Boombox
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Need to copy audio cassette onto my pc.
GET YOU A JACK TO PLUG RCA JACK S ,,FROM RADIO SHACK ,,,PLUG TAPE PLAYER TO CPUFOR AUDIO INTO YOUR CPU,,
May 12, 2009 | JVC Audio Players & Recorders
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
JVC RC-QN2 - How to use the microphone on this unit?
That model seems to pre-date JVC's online manuals.
Let's try a little logic here though:
- Can it record on FM?    No - Can it record on CD?   No - Can it record on tape?   Probably. And if it is set up as most such devices, it will have to be switched to 'Tape,' then 'Record' and if you don't wish to actually put anything on tape, you may still have to have one in the drive and just leave it on 'Pause.'
Sep 14, 2008 | JVC RC-QN2 Cassette/CD Boombox
215 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
