Question about Epson CX8400 All-In-One InkJet Printer
Put two new printer inks in and now nothing prints - don't know how to fix it. It feeds the paper through but nothing is printed on the paper.
    Master:
  • 969 Answers
Did you remove the tape from the bottom of both cartridges? Remove both & re-install.
Posted on Nov 07, 2010
Does not print.
print a test page from Windows...if nothing prints, you need new ink
Jul 21, 2012 | HP Office Equipment & Supplies
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Hello, our C66 printer won't print. It has been unused for about 2 years, we've put all new ink cartridges in, downloaded the latest drivers, and nothing gets printed. You can go through all the test...
The most likely cause is the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 06, 2011 | Epson Stylus C66 Inkjet Printer
I have never had a problem with this printer until now. I have installed new black & white as well as colored ink, but the power & paper lights flash, and both of the ink-out lights stay on. The...
Sad to hear that mate. I've still got mine and it works like a dream. I can leave it for years without printing anything and after a few head cleans it still prints like new.
Try and get another one because its that good and replacement ink costs
Sep 21, 2010 | Epson Stylus 880 InkJet Color Printer
PAPER FEEDS TO START, THEN PRINTING STARTS, BUT
Hi there
This is some imes only down to cleaning the rollers with some worm water cleanthem all and you may be in luck.
All best Pineworks
Apr 29, 2010 | Lexmark X5495 All-in-One &USB...
Why the epson stylus C86 dont print nothing?it makes noise like its print but on the paper nothing
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
You can run a printer check to determine whether a problem comes from the printer itself or some other source.
1. Make sure both the printer and computer are turned off. Then disconnect the interface cable from the printer.
2. Make sure letter-size plain paper is loaded in the printer.
3. Hold down the paper button, then press and release the power button. Continue holding down the paper button until the green power light starts to flash, then release it.
If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the ink button on the printer for three seconds. (This only works when the red ink light is off.)
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus C86 InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
S520 will not print in any color
If you have tried to print a nozzle check page and no ink has been deposited on the page, then it might be a bad logic board inside the printer or a faulty purge unit. Both parts are relatively expensive to purchase. You might be better off looking for a used Canon s520, i550, i850, pixma 3000, or similar model to use the remaining ink cartridges if you can locate one in good condition and not more than 40 USD. xcd187
Oct 03, 2007 | Canon S520 InkJet Photo Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Epson CX8400 All-In-One InkJet Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
