SOURCE: Bose 901 VI speakers used with sub woofer and Bose mo. 141 rear speakers
just connect 2 speakers to each output.
SOURCE: Which subwoofer????
Cameron,
I have the same problem, check these link and you will understanding more how it works. My understanding was bose cube cannot work with other receiver directly, it has to be work with bose's woofer (they call module) and they have specific wire to connect. So I give up to switch to bose even they match my deco and go back to traditional. Good luck.
http://www.allbose.com/Question.aspx?id=64108
http://products.bose.com/pdf/customer_service/owners/am6_guide.pdf
SOURCE: Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
SOURCE: Bose 901 speaker with eq
You want them to be your Main Front speakers, right? The news is not good.
There will be some limitations because you can't extract 'processed' L-R from this receiver. The following will give you good stereo and Front L-R from the 901's but it won't allow central volume control or send them any of the DSP effects you may select. Sorry. If it had a Front L-R Pre-Out you'd be good to go for all functions and listening modes.
You'll need a separate stereo amplifier WITH ITS OWN VOLUME CONTROL for the 901's to accommodate the need for the Active EQ. Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
With this receiver we have to cheat to get the Front L-R signal out to the 901's (but it's unprocessed and at a steady volume level)...
For connection I would run a pair of RCA cables from the VCR/DVR Audio Out L-R OUT jacks (*) to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp.
* You'll lose the ability to use these jacks for anything else, but few of us use them anyway. DO NOT select this function for monitoring or you lose all audio in the Onkyo.
SOURCE: bose speaker connection
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
