Question about LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive
LaCie Big Disk Extreme 1000 GB Hard Drive - A year ago the HDD stopped working, no blue light, no sound of the drivers or spinning fan. I tried to change the cables of the power adapter couple of time but it didn't work. Then I open the HDD and I checked if any cable or cheap was unplugged or broken, i unplugged everything and then I plugged it back as it was. Again nothing happened. I was sure I killed the HDD but i kept it aside. Last week I tried to plug it again and the power was on again, everything but the fan and the fact that computer says that the drive is unreadable (i have a mac OX 10.6) and then I tried it on a XP and even though the system notifies on a new hardware it fails to show the drive. I read on Lacie's website that there might be some problem with LaCie Big Disk Extreme 1TB on mac ox 10.6, but I doubt it is the case since it doesn't work on XP as well. Though the HDD formatted to mac and I know that sometimes XP doesn't recognize drives which are not formatted to FAT. On the disk utility I have the option to re-format the drive and I guess that it will be usable again but I struggle so hard because I have some important data on it. you have any solution? should i try to plug it to 10.5 any way? should i try to plug it to other HDD cover ? I have another HDD, but it has only drive not 2 as in the EXTREME HDD. or any other solutions?
  • 42 Answers
SOURCE: help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Posted on Dec 09, 2007
SOURCE: Lacie drive won't mount
Ive solved the Whole Lacie wont mount problem.... Thanks to Lacie support center, Best Buy, The internet and several Tech shops I took my crashed lacie d2 quadra 500 GB hard drive to for help when it crashed. They didn;t help and none of the stuff I bought helped either. Here is the solution: Take any of your crashed lacie Hard drives (That are clicking and making a noise to a Windows OS) FOOTNOTE: NO MATTER WHAT ANYONE SAYS, YOUR LACIE HAS NOT CRASHED AND DOES NOT NEED DATA RECOVERY$$$$$$$$ Take it to a Windows (XP worked on mine) install your lacie one button disk, after its installed properly, Run the lacie one button recovery by clicking the blinking and clicking switch on the hard drive the program will come up and show the Lacie Hard drive. Go to windows control panel and run add hardware program and search once. (if it hasnt mounted it will not find it) just let the search go through once and after it says can-not find hardware leave it open. Go to My Computer and open it, keep the window open that shows all of your drives. Wait about 4-8 hours depending on what you have going on (go to the movies or go to sleep) and come back and your lacie drive will be mounted. (THIS IS NOT THE LAST STEP- DONT GET HAPPY YET) This is whats going to burn your attitude to a new level. The Lacie Hard drive is SUPER un responsive. I advise opening just the main window and taking a look at all the folders and files you have on them. ( i solved mine by simply erasing the Video files. Final cut pro cache folders etc.) if you use your hard drive for things like editing video and audio then more than likely your drive is slightly corrupted (don't get angry) this does not mean its trashed, it means that there is a problem with file structure and a single or several files confused the hard drive. Once again your lacie is not trash. I used mine for video editing in Final cut Pro, and Audio in Pro Tools, among other things like saving photos and software, etc... Just take the time to simply delete what you know you dont need.. or even better, format the entire drive and it will be like new. Another step you can take in mounting your Lacie is to download Mac Drive 7, install it on a PC- not MAC, this process WILL NOT work on a MAC (none of these steps will work on a mac- Trust me, not matter what these nerds say, dont believe that it will- its going to cost you.) Install the Mac Drive 7 on a pc, run the Error Check and repair function and it will take about an hour depending on what you have on your drive and how many errors are found. and It will fix the drive. As stated previously - these steps will ONLY MOUNT YOUR DRIVE. Access to the files and folders on your drive will be very unresponsive. Basically if you plan on copying a movie to your desktop forget about it. 30Mb would take about 2 hours. 6Kb took close to 4 mins to copy from the lacie. You wont be able to back it up so forget about that too. Just follow the begining steps and find out what has done this to your Lacie (you know what it is!). As stated previously- I used my LACIE D2 qudra 500 GB Hard drive (that is only 6 months used) for average things like downloading, uploading, saving, etc... the same things you do, Plus I ran Final Cut Pro, Pro Tools, Logic Pro, and a S**T load of other programs on this drive and what confused or "Corrupted" my lacie and made it BLINK, CLICK, and make STRANGE
Posted on Mar 19, 2008
Crankstart
  • 696 Answers
SOURCE: trouble seeing my lacie drive possible mounting issue
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
Posted on May 29, 2009
Crankstart
  • 696 Answers
SOURCE: LaCie Big Disk Extreme 1TB Hard Drive - continuous beep, no power
Hi, Lacie isn't very forthcoming with beep codes but it definitely means one of the two. You can try moving the hard drive into a new enclosure, if it works it was the enclosure, if not the HDD. Hate to say it but warranty on these drives is a moot point the moment unique data is stored on them as you can't even diagnose the problem properly without voiding it and no drive manufacturer will waranty data. If you have no unique data and it's under warranty, send it back. If you have unique data on it that you value, take it to a local computer store and have them move the drive to a new external enclosure and test it. If it works, you're done. If it doesn't, you've confirmed that the HDD is faulty and you will need the help of a data recovery Pro. If the latter is the case, reply by commenting here with your location (country, state city) and I'll recommend a closeby facility for you. Chris
Posted on Jun 05, 2009
  • 1768 Answers
SOURCE: LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Posted on Jul 08, 2010
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Hard drive not booting
Test the power supply with a volt meter. You should be able to hear the hard drive spin just by putting it up to your ear.
Dec 04, 2009 | LaCie Big Disk Extreme (300797U) 1000 GB...
Pc not recognizing drive when turned on
Maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Have you tried the disk on a different system?
Jules
Apr 02, 2009 | LaCie Big Disk Extreme with Triple...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
My LaCie big disk extreme+ 1000GB isn't starting and I don't know whats the problem, i doesn't want to boot up. What can I do to get it to start. Its been working fine for a year now and today when I...
Hope this helps??!!
Posted Oct 13, 2006 - It's not the drives that fail, it's the power supplies... They fry after about 3 months-1.5 years. LaCie sells replacements for about $16-$20, dpeneding on the model. We have over 20 of these drives, and here's how you know: the drive spins up, then down - it tries to mount, data transfer will freeze, etc. Just put another power supply on it, and 9 times out of 10, it's fine. Of course, any drive can fry on you, but these have proven to be extremely reliable under some of the hardest use imaginable.
Nov 28, 2008 | LaCie Big Disk Extreme (300797U) 1000 GB...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive Logo
48 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
