Question about Bosch SHU3036UC Dishwasher
Our Bosch SHY56A02UC/14 runs with the door open. The diagnostic test recommended on Bosch's website doesn't show anything. Is there something I can do here ... a switch or somthing like that?
5 Suggested Answers
  • 5 Answers
SOURCE: My Bosch SHV46C dishwasher keeps running, even
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Posted on Dec 27, 2009
SOURCE: i have a bosch shu43c02uc-22 i kept running
In most cases this solution does the trick http://www.fixya.com/support/t7219890-dishwasher_taking_2_3_hours_run_cycle
Posted on Dec 17, 2010
  • 3247 Answers
SOURCE: My bosch shx46a05UC/14 will not shut off. I can
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Posted on Jan 28, 2011
Daniel S
  • 4323 Answers
SOURCE: BOSCH Dishwasher Model # SHX46B06LIC/14 Has
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 21, 2011
Power window wiring diagram for 1998 Lincoln town car
Go to http://bbbind.com/free_tsb.html free wiring diagrams !
  • Power Windows Completely Inoperative
  • Window regulator control switch.
  • Circuits open or shorted.
  • Window regulator electric drive.
  • Driver door module.
  • PERFORM Self Test to retrieve Diagnostic Trouble Codes. If no DTCs retrieved, GO to Pinpoint Test C .
  1. VISUAL INSPECTION CHART
  1. Mechanical
  2. Electrical
  • Front door power window regulator damaged.
  • Front window run damaged.
  • Front door window glass out of window run.
  • Front door window glass broken.
  • Lighting control module.
  • Circuits open/shorted.
  • Loose, corroded connectors.
  • Damaged window regulator control switch.
  • Damaged window regulator electric drive.
  • Power distribution box Fuse D 40 for heated back window concern; Circuit Breaker 14 (20A), Circuit Breaker F (30A) or window regulator safety relay for power window concern.
  • Fuse junction panel Circuit Breaker 14 (20A), Fuses 6 (10A), 9 (5A), 15 (15A), Fuse 13 (10A), Fuse 4 (10A) or Circuit Breaker 12 (18A).
  • Scratched grid.
  1. If the inspection reveals obvious concerns that can be readily serviced, correct the concern before continuing with Inspection and Verification.
  1. If the concern remains after the inspection, connect the Rotunda New Generation Star (NGS) Tester, 007-00500 or equivalent, to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for lighting control module, go to Pinpoint Test B . If the DATA LINK DIAGNOSTICS test is passed for the driver door module and lighting control module, retrieve continuous DTCs and execute self test diagnostics for the driver door module and lighting control module to retrieve current DTCs.
  1. If self test is passed and no DTCs are retrieved, go to Symptom Chart to continue diagnosis.
  1. If DTCs are retrieved for the driver door module, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index to continue diagnosis. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the driver door module cannot be accessed by the NGS tester, go to Pinpoint Test A . If the lighting control module cannot be accessed by the NGS, go to Pinpoint Test B .
Rotunda Service Bay Diagnostic System (SBDS®) 001-00001 may also be used to diagnose this system.
You'll need more then wiring diagrams ! A good scan tool for starters .
Youl
Aug 08, 2016 | Lincoln Cars & Trucks
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
The screen shows F26, is there any thing i can do
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My bosch dw gives a error code of 1 this is an over or under water filling fault not a heating error which is posted on this site which one is correct
Hello, welcome to Fixya. Actually an error code "1" refers ONLY to a heating error. I'm not sure what you've based your info on, but "1" being displayed has nothibg to do with a water fill/level issue what-so-ever with any Bosch dishwashers. Here's how to perform a test or diagnostic for the "shu43" series Bosch to determine once and for all the problem you're having though. Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ). Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ). When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time. Let the test follow through. When testing has ended, the display will show an error using codes as follows. "0" = no error. "1" = aqua sensor fault. "2" = heating fault. "4" = filling fault. and finally, "8" = NTC ( temperature sensor ) fault. If it where related to a fill/level error you would see the letter "F" during washing but the # 4 in diagnostic's. Similarly for a heating fault, the diagnostic will identify a #2 but the "1" appears during normal washing. Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating. If there is anything not clear let me know and I'll try to expand on the info I posted. Good luck. Macmarkus :)
Jun 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The door locks when the start button is pressed, but the cycle will not start. Diagnostics shows F26 door lock assembly. Whirlpool WFW8300SW. I have replaced the CCU and it still locks but nothing happens...
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 18, 2010 | Whirlpool WFW8300SW
F-26 flashing
DOOR SWITCH ERROR
5 seconds.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Owners manual misplaced, model SHY56a02uc/14
Hi Friend,
U can download the Manual from the below link provided
http://kitchen.manualsonline.com/manuals/mfg/bosch/shy56a.html
Copy and paste the Link in the brower
in the web page will be having a download button click it u can view the manual
Or if its needed i can send u a mail kindly provide the mail id
Regards,
Ayyasamy
Jun 15, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch SHU3036UC Dishwasher Logo
106 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
