Question about Vivitar ViviCam 5385 Digital Camera
Can I use a 4GB SDHC memory card with Vivitar 5385 camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
No. The 5385 works with SD cards, not with SDHC cards. You're limited to cards 2GB and smaller.
Posted on Apr 04, 2012
Actaviosan
  • 100 Answers
SOURCE: vivitar software for a MAC
Dear Sir/Madam,
I am sorry to inform you that the camera's driver is only suitable for PC. A MAC version of the driver does not exist.
Try and use a help of a friend with a PC to do what you need to do.
Actaviosan.
Posted on Nov 18, 2007
SOURCE: cant format memory card for vivitar vivicam 5188
I cannot format the sd card. The camera stays in the busy mode.
Posted on Jan 22, 2009
  • 18 Answers
SOURCE: Vivitar 5010 camera SD Card Support
Yes this camera supports the SDHC card the difference is more space.
1gb and 2gb are considered regular SD cards. Anything 4gb and above is considered "High Capacity".
Posted on Mar 31, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: Lens cover does not open and camera shuts off it
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Posted on Jun 09, 2010
SOURCE: I just bought a Vivitar ViviCam T027 camera. The
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Posted on Oct 19, 2010
Testimonial: "You explained it perfectly. Your right, Vivitar caused the confusion by referring to an SD card rather than an SDHC card. Thanks for your help."
Card Error
The 5385 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards such as your 16GB card.
Mar 20, 2014 | Vivitar ViviCam 5385 Digital Camera
Will a 16 gb sdhc card work in a vivitar 5385 camera
No. The 5385 works with SD cards, 2GB and smaller.
Mar 20, 2011 | Vivitar ViviCam 5385 Digital Camera
What is the largest SD card I can use? Is there a difference in SD and SDHC?
SD cards max out at 2GB and so the largest SD card you can use with this or any other camera is 2GB.
SDHC is a later extension to increase card capacity. It is backward compatible in that SDHC devices can also use SD cards, but not forward compatible in that SD devices cannot use SDHC cards.
Dec 28, 2010 | Vivitar ViviCam 5385 Digital Camera
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
Have had this camera ages and all was ok till i got a 4gb sd card. I get the message" card error" i sent the card back and got a replacement but the same happens, is this sd card too big for this camera?
Technically it's not an SD card. SD cards go up to 2GB, larger cards are actually SDHC cards. And yes, it is too big. You'll have to stay with cards 2GB and smaller.
Jun 10, 2010 | Vivitar ViviCam 5385 Digital Camera
Just wondering what memory card i need as a 4gb sdhc card doesnt work it saying card fail
Your camera may not be able to use SDHC cards. Try an SD card instead (they only go up to 2GB).
Mar 16, 2010 | Vivitar ViviCam 5150s Digital Camera
I have a vivitar video recorder model no 840 xhd. can you tell me what memory card to get for it. the hand book says I need a standard SD card upto 32GB.but most card have other numbers or letters after...
It can use MMC cards or SD cards or SDHC cards up to 8GB in size.
SD cards top out at 2GB. 4GB and larger cards are technically SDHC (Secure Digital High Capacity) cards.
Dec 17, 2009 | Vivitar DVR 840XHD Digital Video Recorder
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Vivitar ViviCam 5385 Digital Camera Logo
51 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
