I have a Sony DAV-TZ510 sound system, theres no sound coming from the centre speaker?
  • 10 Answers
SOURCE: No sound out of centre speaker
Make sure your amp is set to a channel which plays on all speakers (5.1).
If you have the amp set to "Stereo", it is only the frontspeakers and subwoofer which play sound.
Posted on Oct 14, 2008
  • 36 Answers
SOURCE: Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Posted on Feb 10, 2009
SOURCE: COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Posted on Jun 04, 2009
SOURCE: no sound - sony dvd
como le ago para caundo este viendo las caricaturas o programas de tv suenen las vocinas
Posted on Oct 11, 2010
bobhifi
  • 635 Answers
SOURCE: my sony dav dz270 home
You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
Posted on Mar 14, 2011
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
My sony dav dz270 home theatre has no sound through centre and rear speaker
Mar 14, 2011 | Sony DAV-DZ720 Theater System
My dav-dz270 has no sound from the centre and rear speakers. only the sub-woofer and front speakers produce sound.
Make sure your sound mode is set to Dolby Pro logic II. This will force it to produce sound from all of the speakers.
Mar 13, 2011 | Sony DAV-DZ100 System
Our Sony c 770 no longer plays DVDs or Cds but it still works as a receiver. Can we connect a DVD player to it and have it come thru the 5.1 speaker system?
Yes, tis unit has 2 video inputs at rear so you can connect any other dvd player sound (analog or digital) to get 5.1 channel surround sound from DAV-C770 speakers.
Click Sony Support to download user manual copy of DAV-C770 that has more details about connection setup.
Hope this info will help you.
Thanks.
Nov 26, 2010 | Sony DAV-C770 System
No sound - sony dvd home theater dav-tz210/tz510/tz710-playing mp4 movie through flash memory
Oct 01, 2010 | Sony Televison & Video
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony DAV-S300 volume is unchangeable from either remote or knob. Any ideas?
Is the sound coming from the speakers you have installed, or from the speakers on the TV itself?
Dec 19, 2009 | Sony DAV-S300 System
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
No speakers?
if you are trying to get rid of all the speakers & just hooking up the sound to the tv speakers, what you need to look for on the back of the dvd system is you need to find an audio out. I know the is one or two audio input, but I do not think there are any audio outputs. I don'e think you can get sound out of this system without your speakers hooked up. sorry.
Oct 31, 2006 | Sony DAV-SA30 System
146 people viewed this question
 Grubhead
Grubhead
