Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My 2007 craftsman 17.5 hp tractor runs fine but when I puy it in gear or engage the blades it stalls
Sounds like a safety shut off switch is in the open position or came loose and isnt making the connection. most likely the one in the seat, lift the seat and disconnect the wire harness plugged into the bottm of the seat attatch a jumper wire to the terminale on the wire harness to close the loop to trick the mower to think there is a rider on board and carefully put seat down so wire dont fall off, sit, start and try to drive and or the blades, it should not stall if the jumper wire is attached, if so either replace the switch or reconnect and try again and you should be fine , DONT USE MACHINE WITH JUMPER ATTACHED FIX THE PROBLEM FIRST, ITS A SAFETY SWITCH FOR A REASON, just use the jumper for the test then remove.
Posted on Nov 10, 2010
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman 917.287030 and it will not stay running. i put it in gear and it stalls. any ideas??
Check the seat safety switch. For example, start the mower and then engage the blades. If the seat safety switch is faulty, then it will die. Same thing with putting it in gear and releasing the brake.
I hope this is helpful for you.
Aug 22, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
120 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
