Question about Car Audio & Video
I need to know what does the colors on the harness to the sony radio mean?
    Sniper:
  • 59 Answers
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this is what you were looking for.
Posted on Nov 08, 2010
91 geo prizm
pre standard year, for radio colors, sorry.
there are 2 colors, factory harness side and radio side,
i presume you mean Radio side? (the radio side of conn?)
it's all here, alldata.com
a discount is here, cheap
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
i uses mitchels but this is a better deal.
no need to guess.?
Dec 22, 2012 | 1994 Geo Prizm
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
I need help installing a new radio.
Hi my names Josh and yes you will need a harness if you havent allready purchased one. Plugging your new harness in is very easy and from there you just follow the colors from the new harness to the colors on the harness wires coming out of the new car stereo reciver Red with red yellow with yellow black with black. white with white gray with gray make sure you pay attention to the white and gray wires they are marked one with stirp and one without one you want to put white with stirp toegether with the white with stip on your harness like wise with your green and your purple
Mar 02, 2010 | Buck Saturn Sc1 Sc2 1996 1997 Radio...
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Need color codes for new radio to 99 nissan sentra
Hello jmartinatl,
The color codes for your receiver is here.
Just match the function of each wire the the appropriate wire on your vehicle. Or better yet, purchase a vehicle specific aftermarket wiring harness that plugs into the vehicle wiring.
Hope this helps.
Jul 24, 2009 | JVC KD-G200 CD Player
95 olds aurora radio wiring
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY/BLACK (+) RADIO HARNESS
Dimmer BROWN/WHITE (+) RADIO HARNESS
Power Antenna DARK GREEN (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location TRUNK,ON BACK SEAT
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Apr 12, 2009 | Sony Car Audio & Video
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
I need to know what colors mean what, so i can hook my cd player up
Red - Power
Yellow - primary power must be joined to the red
blue - Remote
Black - ground or negative
To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash.
or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right.
If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
Oct 09, 2008 | 1991 Honda Accord
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
