Question about Samsung SCX 4521F All-In-One Laser Printer
Not recieving only in memory
We are not recieving the faxes, they are going to the memory, how do I retrieve the fax?
  • Anonymous Nov 03, 2008
    How you do actually print the faxes that have been saved in your unit's memory? So you can see what you missed?
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Posted on Jun 17, 2008
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
How to retrieve faxes in memory
take out the paper or toner and the faxes will recieve in memory!Its the only time it will go to memory!
Feb 08, 2010 | Canon FAXPHONE L80 Laser
How to retrieve incoming faxes stored in memory? display still shows "load paper" after paper is loaded; are the two problems related? Thanks.
Yes and u need to press stop on the m/c or clean the grey roller at the back where u put in your recieving paper!
Jan 21, 2010 | Canon FAXPHONE L80 Laser
Can't get my intel fgax 1860c to receive fax's....just started...it will ring and says it is recieving but i get no fax....
Hi
Thanks for using FixYa. Receive faxes to memory option might be enabled and all the faxes are been stored in the internal memory and not been printed. to retrieve them you can try printing from the memory. You can retrieve these faxes by changing the receive mode from main menu.
You can also see the operation guide for your Intellifax model 1860c from this link--
Brother Intellifax 1860c operating instructions & guide
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | Cell Phones
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for paper....is it displaying an error code?
Aug 03, 2009 | Canon LaserClass 2050 Plain Paper Fax
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
I dont remember how to recieve a fax!
I find that you have to have the fax button lit up. If it is not lit up when a fax comes in, the fax is stored in the memory. You have to hit the fax button, go into the menu and go to memory reference, then the doc # of the item in memory should appear. You should then be able to print the stored fax. Hope this helps!
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Samsung SCX 4521F All-In-One Laser Printer Logo
421 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
