Have an old rheem heat pump split unit. Replaced condenser fan motor and contactor. Compressor and fan both come on when you manually trip contactor, but will not come on from thermostat. Was pretty careful about connecting everything correctly to new contactor. Any suggestions?
  • Jethro Bodine Nov 09, 2010
    Was tracing low voltage wires to find transformer and found yellow had become disconnected. Problem solved.
  • 674 Answers
Remove the thermostat face and place a jumper between R and Y. The outside unit should come on. If it doesn't, check for 24vac between R and C or R and Y. If you don't have it then you need to check the transformer. Check for 24vac on the transformer secondary and 120vac on the transformer primary. If you don't have power on the primary, check for a blown fuse or tripped breaker. If you do have power on the primary but nothing on the secondary, you need a new transformer. If the unit does come then the thermostat is the problem.
If the transformer is good and the unit doesn't start when you install the jumper then you have a problem in the outside unit. It could be the contactor coil which you can check with an ohmmeter. It could also be a low or high pressure switch or and overload all of which you can also check with an ohmmeter. Let me know what you find.
Posted on Nov 08, 2010
    Was tracing low voltage wire to find transformer and found yellow was disconnected at a splice. Reconnected and problem solved.
Why contactor on heat pump will not energize heat mode?
Heat pump and AC are basically working the same principle. When you turn on the heat pump is just like to turn on the AC. The main contactor will energize to turn on the compressor. The only difference is the 3 way valve, either switching to AC mode or heat mode. It is the most commom problem for heat pump. Check the thermostat wires for heat mode and defrost control.
Feb 05, 2015 | Heating & Cooling
Rheem RAKA-060JAZ trouble question
pls check for compressor shorting and relay issue in pcb
Oct 12, 2013 | Heating & Cooling
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
I have a goodman manufacturing 3 ton heat pump, model #CPLE36-1. initial call was no a/c. found breaker tripped. reset and hit disconnect and tripped again.. ohmed compressor and fan motor and both ohmed...
What you need to do is disconnect the compressor at the electrical access on the side of the unit. Check each wire to the grounding screw using ohm meter if you get continuity your compressor is shorted do the same thing for you condenser fan. I bet your compressor is shorted. Make sure power is off and remember where the wires go. Trace the wires that go to compressor back to the contactor and capacitor and disconnect them there. If this help please rate me and do a testimonial.
May 25, 2011 | Heating & Cooling
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
Condenser Fan and Compressor not turning on.
Are you sure you have high voltage going to the unit? One wire from fan lands on top left of contactor, the other two go to C and Fan on capacitor. Manually push in contactor, if no fan than no high voltage.
Jun 05, 2017 | Carrier 38CKC060 Air Conditioner
When the unit is in heat mode is the fan on the outside supose to run? Capacitor on outside and inside have been replace fan was running when capacitor was first replaced.
Hi, and the outdoor condenser fan should not be on at all in the heat mode unless this is a heat-pump!! So, I can see that this is a 3-ton Carrier split system and I haven't pulled up any information on it, only if I need to. But if the indoor unit runs on natural gas/propane, this would not be a heat-pump and the outdoor fan would run only in the cooling cycle. So, if it is not gas fired it is a heat-pump, and yes the outdoor unit should be up and running all year around. On a heat-pump you will have what is called a reversing valve in the refrigerant system that directs the flow of freon in the right direction for the season you are in. Most all heat-pumps will have a heat strip package installed in unit for emergency and aux. heat if compressor lets say fails. You're thermostat will have on it a selector switch, you will see on it these labels, Aux., emergency heat, auto/on/off/heat/cool. You will know from what I have just went through with you what you have. Forgive me for such a long explanation as I like my customers to understand more about there units in question. I could have just said yes or no and thanks? Doesn't work like that for me. I hope this has helped you out. One thing, If you determine this is a heat-pump and the fan is not on when in heat, you may have lost this condenser fan motor? You say both run caps. were replaced, and normally when you loose a run cap for a motor they will open internally, leak, buldge ect. So if this is taking place, if you can yourself take a look at the run cap. Also, make sure you have 220 volts to condensing unit. If not, check breaker probably a 30 amp double pole to see if it has tripped. You will have a disconnect box at the unit and inside there will also be 2 fuses. If you see only a pull out square connect, the fuses are still there but in behind the cover. If you have power and can hear the compressor come on but fan does not, I am positive you will have A faulty run cap, or faulty motor. Kill power to unit and try and slide a metal coat hanger down to prop or blade to see if it spins freely. If it is hard to turn bearings are froze up. If the capacitor seems to look ok, and the motor does spin free, It still may have open windings. Do these checks I have asked of you on power to the outdoor unit. If all is good, Stand in front of the unit and have someone turn the stat on for what season you are in. Lower or raise temp a ways above or below room temp. You should her the contactor close and compressor will start along with the condenser motor.If compressor starts and motor does not, then I would say it has failed and or cap again. When a motor is replaced, the run cap must always be replaced to!! Please get back to me and keep me posted. I will wait to hear what has happened. Good Luck.
Sincerely,
Shastalaker7
Jan 13, 2010 | Carrier 38CKC036 Air Conditioner
4 ton rheem 3yrs old thermostat
It is possible that the relay in the thermostat for "cooling" has gone bad. The relay that runs the blower is different than the condenser relay. Check that you have 24v AC coming from the t-stat to the "y" terminal at the air handler. That same "y" wire should go out to the condenser, make sure then that you have 24v out there. If you have 24v at the condenser then see if the contactor is pulling in. If not then you may have a loss of charge switch that is stopping the current to the contactor. See if you have 24v to the coil of the contactor. If the contactor is pulling in and power is going to the compressor then the compressor has failed. If this is the case the condenser fan will be running but the compressor is not. If neither the condenser fan or the compressor is running then you have a problem in the 24v circuit, which could be a bad wire or a safety switch.
As you can see there are a number of possibilities for your problem. You will need to methodically go through everything to eliminate the possiblities till you isolate the problem,
I hope that this will help you to solve your problem and get you cooling again!
Thanks for using Fixya!
Heatman101
Nov 23, 2009 | Air Purifiers
Goodman heat pump the fan runs but blows the 3amp fuse
The 3 amp fuse is for you're control voltage only, which is 24volts,ac. Something in the control side of your unit has a direct short in it. Since I am not on site to help you find out what part is at fault, I will give you some things to check out.You say you're indoor fan runs. I can only assume when you put the thermostat fan to on and not auto. Since this is a heat-pump, and not a gas fired unit, you will have a few less things that are 24volts.You say it blows the fuse on both heat and cool. You or someone that may give you a hand needs to do a process of elimination. What you will need to do, is to check all of the 24v. components to see which is at fault. The 24volts via relays and coils are what controls the motors, compressor, ect. We know that the indoor fan is good. I would be looking at the contacter coil first, even though the thermostat is 24volts. Since the contacter controls the condenser fan motor and compressor, my guess would be the coil on your contactor is shorted. I am not sure if you're heat-pump is a package unit or a split? Either way, you need to open up the control section of the compressor section which on a split its the outdoor unit. On a package unit, its where the main power enters. That would be on what ever kind of Goodman you may have, the 220volts come in and each of the 2 hot wires connect to the bottom of the contactor.What to do 1st.What ever it is, a split or a pack unit, turn off the main power to unit, split, outdoor unit, pack, whole unit.Even if this is a split system, when you turn the power off to the outdoor unit, you will still have 24volts to it when you turn the stat on.The 24 volts comes from the fan center on the indoor unit. With all of the power off, look at the contactor. On each side you will see 2 wires to a copper coil. Pull off these 2 wires, and dont let them touch anything even though they are dead.Turn power back on and check the 3 amp fuse. It should be fine. Now, with the power turned back on, touch these 2 wires back to the coil.This should blow the fuse. If it does, that contactor needs to be replaced.I know this is a lot to check, but I am sure the contactor coil is shorted. You will have to buy one from a retail appliance store. Every wire must be put back in its original place. If you don't think you can test this, I would advise calling someone out. I know this is a long solution, but i am sure that is the problem. Let me know please. Good Luck,
Shastalaker7
Ps an electrical meter would be of a lot of use to you. One more thing, if the copper coil on the contacter is burned and black, just turn off all power and replace it. I am certain this is your fault.
Nov 12, 2009 | Heating & Cooling
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
