Question about GE JKP86 Electric Double Oven
Greetings- A while back we had troulble with the oven portion not working on a GE JPK86 double wall oven. The oven portion did not work. I believe that the technician replaced the oven control (possibly WB27T10500). Since that repair, I have noticed that the timer and clock on the oven portion do not keep the correct time. When I tried to set the the microwave and the oven clocks back this weekend as part of the EDT to EST conversion, the microwave clock is still accurate, but I have noticed that the oven clock appears to advance one minute every 50 seconds. I am wondering if there is some sort of 50 Hz/60 Hz setting or switch for the oven control unit, and whether it may have been overlooked or set incorrectly by the technician. If this is the case, how do I fix it?. Is there an obscure keyboard sequence which I can use to change from 50 Hz to 60 Hz? Is is necessary to open up the unit (I would probably call a technician for this)? If I do call a technician, what do I tell him/her? Would it hurt the oven if I continued to run with the wrong setting on the 50/60 Hz option? Could I wait until something goes wrong and have it fixed at that time, or do I have to put in a special call soon? Please advise Gerald W. Murray
  • Gerald Murray Nov 08, 2010
    Somewhat helpful
    Thanks for your assistance
    Regards.
    Genius:
  • 1,340 Answers
The Hz will definitely affect the clock because that is the basis for a timer,counting the Hz.I do not see your exact model listed at a site which I commonly use for looking at manuals,but there is one only a couple of numbers off(JPK90),and they are usually very similar.With a 50 Hz setting,30 minutes is actually 25 minutes of bake time if you are in the USA,which it appears you are.Since it was replaced,just about everything you baked was likely undercooked after the proper time.I believe Europe,maybe Canada too,uses 50 Hz and it may in fact be the wrong part.Rats.I went to geappliances.com and tried to find out the specifications for the part number you listed,which appeared to be correct :) but it would only list the part.I tried to be as specific as possible in searching for it.The lowest number of hits ended up being about 555.With each search,perhaps 5,I looked through about 8 pages and still nothing.Here is the best thing to do.Call whoever fixed it previously and ask for a supervisor or manager.If the person asks why,simply tell them briefly why and just be adamant about speaking to one.They should end up checking the part number for correctness and specifications and if they did use the wrong part,they should replace it with the correct one at no cost since you have already paid for it and it was their error.The part number you listed was about $160.You should either get some money back if the correct one costs less,or if it costs more,insist that they repair it free anyways,due to their error.I have done some work in this field and they should have no problems with your request if it is the wrong part.If they want more money for labor,you should not have to pay it if they are a good,quality repair center and if it is not GE themselves.Good luck,Greg
Posted on Nov 08, 2010
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
How do I uninstall a GE double wall over?
The instructions come with the oven. And differ with models. Most important to follow all items. If the instructions are lost , Google GE double wall oven ( give model number). Or try the GE Dealer.
Aug 23, 2014 | Ovens
I got a GE double wall oven and when I turn the oven on code F1 comes on
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE Built-In 24" Double Electric Wall Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Only bottom of the electric double wall oven works . lts a 1969 G.E.
If you can, test for power to the element in the top oven. If there is power coming to the element, it could be that the element is bad and can be replaced. If there is now power coming to the top oven there could be a more serious issue in a 40 year old oven
Nov 30, 2009 | GE JTP27 Electric Double Oven
GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Jul 15, 2009 | GE JKP50SH Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
GE JKP86 Electric Double Oven Logo
114 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
