Question about Samsung SCX 4521F All-In-One Laser Printer
Not Recieving faxes
The message appears the fax are in the memory. How do I print?
  • Anonymous Jun 24, 2008
    Please can samsung or someone offer a solution that works. Our Samsung SCX - 4521F receives Faxes and when it has finished receiving faxes it does not print them out. This makes it completely impossible to do business. Please find a solution to this problem. We are desperate!
  • 193 Answers
Send yourself a fax. if it goes not print out the fax, something is wrong with the modem. OR buy a newer MFC.
Posted on Jul 07, 2008
Dcp 7055 brother printer in error - print unable ec
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Note
    In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set.
  4. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Start.
Step2: Verify and Transfer faxes in memory
Step3: Reset the machine After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, do the following based on your country:
<USA>If your unit is still within warranty, try to locate a Brother Authorized Service Center in your area or google to obtain contact information for the appropriate Brother Customer Service Center.
If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Aug 04, 2013 | Office Equipment & Supplies
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Step1: To clear the message follow the steps listed below:
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-3.Check the print head's position.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Step2: Check if the machine has faxes in its memory
1.Transfer the Fax Journal Report
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Says: Unable to Clean Consult owners manual
Dec 16, 2010 | Office Equipment & Supplies
Unable to print 5A
Dec 15, 2010 | Brother HL-4040CN Laser Printer
Memory is full
Please follow this instructions; i don't know whether you've disconnected or not but it's been disconnected from my side. So i just wanna give some more hints to fix your problem;
Press the Menu key on the control panel.
Press the Up or Down Arrow key until Fax appears on the LCD.
Then, press OK.
Press the Up or Down Arrow key until Remote Fax Opt or
Advanced Fax Operation appears and press OK.
Press the Up or Down Arrow key until Fwd/Page/Store or
Forward/Store appears and press OK.
Press the Up or Down Arrow key until Off appears and press OK.
If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Or
If you would like to reprint the saved faxes, press 2 (No), press
Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
Press the Menu key.
Then, press OK.
Press the Up or Down Arrow key until Print Fax or Print Document appears and press OK.
After printing is finished, press Stop/Exit.
Good luck. Thanks for using FixYa.
Jun 01, 2010 | Brother MFC-5460CN All-In-One InkJet...
Our Brother MFC 9440CN laser printer memory, keeps saying out of memory. How do I clear the fax memory?
When Fax Storage is set to On, copies of all received faxes are stored in the memory, thus using up a portion of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify that Fax Storage is set to Off by doing the following:
  1. Press the Menu key on the control panel.
  2. Press the Up or Down Arrow key until Fax appears on the LCD. Then, press OK.
  3. Press the Up or Down Arrow key until Remote Fax Opt or Advanced Fax Operation appears and press OK.
  4. Press the Up or Down Arrow key until Fwd/Page/Store or Forward/Store appears and press OK.
  5. Press the Up or Down Arrow key until Off appears and press OK.
  6. If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
Dec 24, 2009 | Brother MFC-9440CN Laser Printer
Cannot clear memory--NEED FOR WORK ASAP!!!!!!!!!!!
Out of Memory message
If the memory becomes full while you are making copies, the LCD
message will guide you through the next step.
If the Out of Memory message appears, press Stop/Exit to
cancel or Black Start or Color Start to copy the scanned pages.
You will need to clear some jobs from the memory before you can
continue.
To gain extra memory, you can turn off Fax Storage.
—OR—
Print the faxes that are in the memory.
When you get an Out of Memory message, you may be able
to make copies if you first print incoming faxes in the memory to
restore the memory to 100%.
Apr 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
43 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
