Question about Hoover F5520 SteamVac Duo Upright Wet Washer
My hoover steam vac will not dispense the water
I did use my cleaner for along time , started it up and no water would
pump.
Posted on Oct 08, 2012
mindreader
  • 578 Answers
SOURCE: The hoover steam vac 5 brush agitator dispenses
You do not have the needed vacuum on the dirty water intake. Possible causes are:
1. No adapter sleeve in the back of the dirty water tank (the one that you remove to put the fabric hose adapter in)
2. The dirty water top is not sealed (cracked, not on correctly)
3. The intake shoot at the front of the unit is clogged with dirt/hair.
REMEMBER: This is NOT a vacuum cleaner - it is not designed to remove hair and dust.... ONLY wet dirt. If you fail to vacuum floors just before steam cleaning, the unit will clog up in minutes!!
Posted on Nov 24, 2009
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
galati2k
  • 281 Answers
SOURCE: Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Posted on May 01, 2009
  • 11 Answers
SOURCE: Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Posted on Oct 22, 2009
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover v2 steam vac F7430-900 the water container will not dispense water only soap yes, any idea to fix this problem?
This is most likely due to a problem with the solenoid on the rinse side not opening. The solenoid may require replacement.
Jan 17, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dispenses Water Only
try replacing the air filter and the water heater.
Jul 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Manual for model f5853-900
I need a mnual for the Hoover Steam Vac Model F5853
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F5520 SteamVac Duo Upright Wet Washer Logo
489 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
