To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control
system.
OSD OPTIONS:
Contrast increases or decreases
display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu.
Color opens the
Color
Manager menu.
Language changes the display language for the OSD control system.
User
displays information
about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
OSD main menu is on the screen appears quite frequently. When pressed the menu button it goes off but appears again. I do not know what to do.
IT is all the time two blue widows for the osd covered with brightness window and theynever go away .they are axactly in the middle and the mouse is always underneeth
I have the same problem. An answer to another similar post suggested replacing the switches- I have no idea what that means. Any other suggestions out there?
osd main controls locked/unlocked pop up flashes every 5 seconds.
OSD menu pops up and it will not stop--have tried restarting machine
OSD stays on or randomly goes on and off.
the osd main menu always on my screen and automatically reaching the maximum level
The OSD menu comes on and off intermittently. This occured a few months ago. We unplugged it and took it to Best Buy without the computer. Best Buy could not detect anything wrong with it. They plugged it up and it stopped. Is this something on my harddrive that's causing the problem? I brought it home from Best Buy and plugged it up and it started again. Then I downloaded a free trial registry program and after running it, the menu stopped. That was many months ago. Now it has started up again. We think we'll buy a full registry program and see if that helps any. Anyone have any suggestions?
