Question about Bosch Washing Machines
I have a Bosch Classixx WAE24363GB All of a sudden the programmes won't start. The time appears on the display and instead of starting the programme is goes to the finished '0' with the beeps and the flashing lock sign. Help!!
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 228 Answers
SOURCE: LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Posted on Oct 20, 2009
  • 662 Answers
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
  • 500 Answers
SOURCE: washer Bosch Classixx 6 1200
You need to press 2 buttons simultaneously for 3 to 7 seconds. Look for a small child's face or a lock icon (Sometimes both) on the Facial panel, there will be arrows pointing from that icon towards 2 buttons, these are the 2 you need to press.
Hope it helps
* If you found this solution helpful, please vote positively.
Posted on Feb 18, 2011
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE DOOR THEN TRIED TO PUT IT ON A PROGRAMME AND IT CAME UP -0- AND IT WOULD NOT START NO TIMES WAS COMING UP WHEN I TURNED THE DIAL ONTO A PROGRAMME.PRESSED...
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx will not start
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
Mar 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Jul 31, 2008 | Washing Machines
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Open Questions:
Washing Machines Logo
61 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
