Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
He3 bellows Hi there, I've just replaced the rubber bellows on my machine after finding holes worn though it in three spots from rubbing on the basket during spin cycle. I noticed on my first load afterwards that the bellows was deformed and socks ect. were getting caught in the bellows. after the cycle was complete the bellows returned to correct form. What needs to be replaced to support the drum under load to maintain the shape of the bellows and prevent more worn holes?
  • jennndtim Jul 03, 2008
    I have kenmore elite he3 110.4282. Clothes (kids socks, face cloths) keep getting caught behind the wash drum and into the drain hose. I just had to take off the lower front panel andopen the drain trap. I pulled out earplugs, nails, candy wrapper. tried machine and wouldn't drain. disconnected drain hose and was able to pull out a wash cloth. Works now but socks were caught inside rubberseal between tub and door. The rubberseal has a tear in it. What is the nme of the rubber seal? is it a bellows or a door seal, and how do I replace?
  • 261 Answers
Alright first I would check the level front to back and get a linen bag designed for the smaller items. Second I would test the basket by pulling slightly and lfting, if no wobbles then ok try push pull to check for a loose spindle at the flywheel on the back.
Posted on Sep 07, 2008
Whirlpool duet washer is putting holes in clothes. The gap between the stainless drum and rubber bellows is about 1/2 inch. Do I need to replace the bellows or the drum?
Tearing or holes if tearing pull the bellow forward and inspect the lip of the front tub for rough spots place your hand in the basket and see if you can push upward looking for play should not have any if so tub bearing worn of holes take a flashlight and inspect the SS basket looking for raised dimples.
Sep 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The water drips out excessively at the top, there is asecond hole where it comes out
When this happened to me, I found that the filter basket had worn and wasn't lining up to catch all the water from the bypass line. I used a small rubber rod behind the lower connector post (where it attaches the basket to the coffee maker) and that forced the top of the basket back far enough to catch all the water. I am using that until I can find a replacement basket.
Aug 05, 2010 | DeLonghi Caffe Nabucco BCO70...
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
Rubber boot keeps getting holes in exact same spot then leaks
Either its not installed properly or you have some sharp foreign object in the basket or tub
Mar 06, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Worn out bellows
The bellow definitely should not deform in the manner that you describe. When you replaced the bellow, did you line it up correctly? There are alignment marks (Arrows) on the tub and the bellow to ensure it is installed correctly? If the bellow is not aligned correctly, it will twist when the tub spins. If the shocks are worn, the bellow could also deform, but you would probably experience excessive vibrating during the final spin. If you are sure the bellow is installed correctly, and wish to replace the shocks, let me know. There are four of them on your washer. I believe they are sold in pairs. If you post your complete model number (located around the door opening), I can assist you in locating parts.
Jun 20, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
Nov 10, 2007 | Whirlpool GHW9150 Front Load Washer
Machine leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains). NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them). 2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety. 3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
175 people viewed this question
Sal De
 Brian Main
Brian Main
