Question about Logitech Webcam
When I plug it in the USB port it doesn't work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Generaly, camera requires USB 2.0. Try connecting it into another usb port. If problem continues, make sure your'e usb ports are running 2.0. Otherwise, camera may be deffective.
Posted on Nov 07, 2010
It doesn't recognize USB flash drive anymore
The flash drive itself may be faulty or damaged, and sometimes this is not apparent from a physical inspection. Try attaching the drive to a USB port that you know is operational, and try plugging another USB device into that port to verify that the port is working.
Jun 19, 2012 | Kenwood KDC-MP445U CD/MP3/WMA/AAC Receiver...
I have just acquired a 500 GB USB HDD and its NTFS formatted, it doesn't show when I plug in SONY BRAVIA USB port
I think it should also come with a power supply also.Does it have lights on it. Try a different port.
Mar 05, 2012 | Computers & Internet
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Computer will not recognize mp3 player, device doesn't light up
The two most likely causes for this is either your USB port or the USB cable itself. Try plugging the device into different ports and if that doesn't work, get yourself a different USB cable. If neither of those works then your device is faulty and the only fix for that is to get it serviced by the manufacturer.
Jul 02, 2011 | Computers & Internet
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
Keyboard doesn;t work at all. Keyboard checks out OK at another PC
Is this a USB or PS/2 keyboard? If it is a PS/2 then the port that is integrated on the board is not working. If it is a USB, try plugging it into another USB port and see if it will work. If it does not work on either port then the ports on the system board are not working. It means u're having some malfunctions on the system board itself.
If it is a USB keyboard and it is that the USB ports integrated on the system board are not working, buy and install a PCI card with USB ports. It should work then.
Mar 15, 2010 | Dell 0Y3740 Keyboard
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Logitech Webcam Logo
29 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
