Question about Akai PDP4273M Television
Akai Plasma PDP4273M with white block and green tint
My plasma when powered on will display a white block in the upper middle portion of the screen approximately 6 in by 3 in. The rest of the screen has a green tint to it. I was wondering what board may cause this and if there is a way of testing something or replacing a few components on the board that may solve the problem,
I have the same problem with mine. I had a repair guy come by and take it apart. He said its either the video board ( about 500.00 ) or the buffer chips which on these tvs are connected to the screen which is not worth the money to fix.
Posted on Jul 14, 2008
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.
https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
Nov 04, 2013 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
F31672et rca tv
Is this a projection/plasma/CRT?
Oct 03, 2008 | RCA F31672ET TV
We have 42" plasma akai
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 31, 2011 | Akai LCT2715 27 in. LCD Television
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
46 toshiba plasma has red tint in back ground
If you can see the red tint with every input source and also in the On-Screen Menu, then this indicates that the Green phosphor is burning off of the screen faster than the Red and Blue. This is typical of plasma screens. Even if you dont watch a lot of golf or football, green is the most dominent color and burns out of the phosphur pits(pixels) faster than the Red and Blue. Take away green, you are left with Reddish looking screen and Pink whites. This is not repairable.
If the Menu looks nice and white, check your source cables.
Good luck
Dec 30, 2009 | Toshiba Televison & Video
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Getting Akai model PDP4273M plasma to accept a new remote
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Mar 19, 2009 | Akai PDP4273M Television
Plasmasync 42 (2004)
the screen abnormality is not plasma burn. it sounds like u may have a shorted driver feeding the panel.
its repairable (might not b practicle)
May 01, 2008 | NEC PlasmaSync 42MP1 42 in. Television
I have some issues with my akai hdmi model pdp4273m
You can download the manual from the akai website:
http://www.akaiusa.com/
I just did a search on "pdp4273m" at the akai website.
http://www.akaiusa.com/products_detail_features.aspx?cat=VISUAL%20ENTERTAINMENT&subcat=Plasma%20TV/Monitor&productno=PDP4273M
The manual is easy to download from there product page about the plasma.
The manual is a PDF, so I hope you have something like adobe acrobat to read the file.
http://www.adobe.com/
Feb 10, 2008 | Televison & Video
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
121 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
