Question about Kenmore Vacuums
Our kenmore progressive model #11634922 was working fine today. And then - it's not. Plugged in - nothing is working on it. We let it cool down (though it didn't seem hot). Still nothing - no light, no motor. Tried it in some other plugs that we know are functioning well - and still nothing. Any idea what might be wrong with it? It's six years old but doesn't get heavy use. Thanks so much ~ Susan Golden
  • teamgolden Nov 07, 2010
    Where might I find the fuse. I've looked at the owner's manual and am not able to locate it there nor on the vacuum itself.
  • 2,382 Answers
Hi, it could be a number of things, cord may be bad as well as a problem with the motor. There also is a fuse that could have blown. If you go to sears.com, click on parts, put in your model number, when the page loads, click on the first link and you will have a parts list, and scroll down there will be a parts break-down picture that you can look at. You can also order parts thru the Sears website.
Posted on Nov 07, 2010
  • Tunde Autos
    Tunde Autos Nov 07, 2010
    Check the plug that goes to the socket or the board panel
My Kemore Progressive dark blue canister vacuum is not yet a year old. I plugged it in as usual, turned it on - nothing. It worked fine last use. Checked power source, etc...
if its under ayear old it should still be under warantry so you can take it back to where you bought it and let them fix it.
Jul 26, 2011 | Kenmore Vacuums
I have a Kenmore Progressive and it will not turn on can you help?
Is it hot when it shuts down the filters may need to be cleaned often,see if this works for you wait for it to cool it may take a few hours.
Aug 29, 2010 | Kenmore Progressive Bagless Upright with...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore 21875
Give the prongs a wiggle and see if there is any play in them.Might just be a plug end.
Oct 18, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Power problem
With out checking it, it is hard to say, I think there is a reset, did you push it? But you do have a years warranty on this, that it into Sears for repair.
Apr 13, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Motor is not working.
Could be a number of things, cord may be bad as well as a problem with the motor. There also is a fuse that could have blown. If you go to sears.com, click on parts, put in your model number, when the page loads, click on the first link and you will have a parts list, and scroll down there will be a parts break-down picture that you can look at. You can also order parts thru the Sears website.
Feb 28, 2008 | Vacuums
Vacuums Logo
42 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
