Question about Brother MFC-3240C All-In-One InkJet Printer
I try to print many things but it just says on the printer that back cover is open please close
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Paper sensor is either clogged or damaged; try to blow some air into the back cover.
good luck
Posted on Nov 07, 2010
Cover open lexmark3480
It could be that one of the cartridges is not seated properly in the cartridge carrier. Please try this approach to fix the problem.
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
Dec 21, 2011 | Lexmark X3480 All-In-One Printer
My printer does not appear to be printing from the black cartridge. I have tried via the maintenance to clean the heads, but when I print it continues to not print. I have also replaced the cartridges.
Hi
Please try this solution
A hard reset of the printer may clear the error. Here is how to perform the hard reset:
1.Shut down the computer.
2.Open the top cover of the printer and remove the print cartridges.
3.Close the top cover of the printer.
4.Press the power button on the printer to turn the printer off.
5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
6.Disconnect the power cord from the back of the printer for one minute.
7.Reconnect the communications cable to the printer.
8.Reconnect the power cable to the printer.
9.Press the printer power button to turn the printer on.
10.Open the top cover and reinsert the print cartridges.
11.Close the top cover and print the calibration page.
12.Restart the computer. If not working, try to clean the ink head manual by removing the cartridge and rub the ink head to a plain paper with alcohol until ink flows on the cartridges and then run the print nozzle or print alignment page. Please let me know if you need more help. Please rate this solution if you find it helpful to you and might help others as well. Regards
Mar 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
WILL NOT CONNECT TO PRINTER. TRIED UNINSTALLING IN ORDER TO REINSTALL BUT MY SYSTEM WILL NOT UNINSTALL THE SOFTWARE. REPEATED ATTEMPTS AT UNINSTALLING ARE PROBABLY CORRUPTING THE SOFTWARE SO NEED HELP IN...
Since you try to uninstall and reinstall the printer software, do you set up again the printer and try to print again the test page.
Most printer if it is not responding is it due to connection error like cable set up, port driver set up or the configuration of the printer or the print spooler had stop.
Please try hard reset of the printer.
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Please let me know if you need more help and do not forget to rate this if you find it helpful to you and to others. Regards
Mar 01, 2011 | Computers & Internet
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
It says ink system has failed unable to print error Oxc19a0020
Hi
Thanks for using FixYa. The error Oxc19a0020 means ink system has failed. Try the following steps to troubleshoot the issue with the printer--
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Reconnect the USB cable, and try to print a print job from the computer.
    Also try this---
· Press the On button to turn the printer off.
· Unplug the power cord from the back of the printer.
· Remove all the ink cartridges.
· Wait two minutes.
· Plug the power cord into the back of the printer.
· Press the On button to turn the printer on.
· Install the ink cartridges when prompted.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
I wish to change unexpended cartridge help ! please.
Unplug the power chord
Open the top cover of the printer.
Remove the print cartridges.
Insert the cartridges back into the printer.
Close the top cover.
Plug back the power chord .
Try printing .
Jan 30, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Unable to print and copy
pls check the trigger switch of the back cover
Oct 16, 2008 | Brother MFC-7420 Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Error Code problem
My mother's printer had a similar problem, I was able to find this solution on the HP site.
Disconnect the USB cable from the back of the printer, but leave the printer turned on.
Open the cover of the printer and remove the print cartridges.
Disconnect the power cord from the back of the printer and wait for one minute.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
I hope this helps you too...
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
14 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
