Question about Feber TT Adventure 12v Truck
Our truck is about 10 months old and I cannot get it to take a charge. I am unable to tell if the battery is charged and there is a loose wire to the accelerator or if the charger is just not working. Is there anyplace that will service these toys (I ma not very techy)?
  • 65 Answers
Go to a toy fixer
Posted on Dec 25, 2010
Battery discharge light comes of when braking, car doesn't charge correctly and starts hard.
The most common cause of the alternator not charging when the belt is wet, is the belt is glazed or not tight.
The only thing that comes to mind to cause the charge light to come on when braking is the engine is shifting and you are loosing a wiring connection or ground.
Sep 05, 2015 | 2005 Chevrolet Chevrolet Impala LS
I have a discharge warning light on in my car. The car will start and run for a while (on a charged battery) but it soon powers down (dash and cabin lights dim to almost zero) and the car shuts off.
alternator or associated wiring suspect... test for 14.4 volts at battery when all is hooked up proper and running.. if less replace alternator or diagnose further the wiring to and from alternator
Dec 01, 2014 | 2000 Lexus ES 300
My battery light is on. what does that mean.
Normally it means a charging malfunction. Could be the alternator, battery, or a poor battery connection or cable, or a loose wire at the alternator. If the battery is over 4 or 5 years old, may be unable to take or keep a charge.
Test the alternator output with a voltmeter on the battery terminals, while engine is running. If voltage reads under 13 volts, alternator is not charging. Check all battery connections for a clean, tight connection, check the battery ground for a clean., tight connection. If no help, take alternator off for testing at a parts store. Likely it is a tired, worn out, or failed alternator.
Dec 23, 2012 | 2001 Isuzu VehiCROSS
Low battery backup
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jun 08, 2012 | Razor MX350 DIRT ROCKET - BLUE
Unable to start. No power
no power usually means dead battery, or loose battery terminal. try moving the terminal and if that fails. try charging your battery, or even jump start it
Feb 27, 2011 | Hyundai Elantra Cars & Trucks
I have a 1991 dodeg dakota sport (v-6) and in the past 3 months i have "gone through 3 batteries and 2 alternators. i pulled trouble codes and the same code comes up, code 12 ( stand by memory power...
CODE 12 STAND BY MEMORY POWER LOST.WHAT IT SAYING ECM LOSING MEMORY BECAUSE LACK OF POWER.POSSIBLE CAUSE TO YOUR PROBLEM COULD BE OLD WORN OUT BATTERY CABLES CAUSING POOR GROUND AND HIGH RESISTANCE IN CHARGING CIRCUIT.YOU COULD HAVE WRONG AMP ALTERNATOR AND BATTERY WRONG COLD CRANKING AMPS.MAKE SURE ALTERNATOR BELT TIGHT AND CHECK ALTERNATOR BATTERY FEED WIRE AND ALTERNATOR FIELD WIRES FOR DAMAGE OR LOOSE CONNECTIONS.CHECK ALTERNATOR FUSE. WITH ENGINE RUNNING ALTERNATOR OUT PUT SHOULD BE 13.5 TO 14.5 VOLTS IF NOT ALTERNATOR NOT CHARGING.
Nov 18, 2010 | Dodge Dakota Cars & Trucks
The lights are on showing that it is charged but will not go. It is only 10 months old.
If the charger is left plugged in longer then 24 hours you may over charge the batteries and they will not work properly. Also You must charge the batteries once a month even if it hasn't been used.
Lift up the back end of the gocart and see if the wheels spin when you pull the throttle. If you only get a clicking sound start by replacing the control modulator. 10 months old your batteries should be still good unless you over charged them. (Leaving plugged in longer then a day) Good luck...
Nov 16, 2010 | Razor 300001-SL Ground Force Go Kart
Battery dead, unable to charge
search craigslist, people all over the place will replace your battery for about $40
Apr 06, 2010 | Apple iPhone Smartphone
Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Mar 11, 2009 | Dell Microsoft Windows XP Home Edition
Feber TT Adventure 12v Truck Logo
277 people viewed this question
Top Feber Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Feber Toy Expert? Answer questions, earn points and help others
