Question about HP DeskJet 952c InkJet Printer
Cartridge light blinks, will not print have inserted 2 new cartridge3s
  • HP Master
  • 7,733 Answers
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
Poor print on my Canon pixma 6150
1. try the deep head cleaning 2. check the content of the cartridge3. be sure that you are using a new cartridge before executing the deep clean4. then print the alignment page 5. after printing the alignment page 6. scan the page on the scanner
Nov 01, 2011 | Office Equipment & Supplies
I bought a replacement black ink cartridge and the cartridge light won't stop blinking or respond at all. Are these cartridges defective?
1.) Reset your printer
2.) Make sure the cartridge are properly inserted.
3.) Does the light still blinking? Try printing a test page if it can print.
Mar 18, 2011 | Office Equipment & Supplies
How to change the cartrige
1.Out tray (in down position)
2. press Power button
3. open top cover
4. raise cradle latch
5. lift out cartridge
6.Remove the replacement print cartridge from its packaging and carefully
remove the protective vinyl tape.
7.Insert the print cartridge firmly into the cradle. Secure the cradle latch.
You hear a click when the latch is fully secured.
8. Close the top cover.
If the Print Cartridge Status light continues to blink after installing a new
print cartridge, check the part number on the cartridge to verify that the
correct cartridge is installed.
Thank You
Oct 05, 2010 | HP DeskJet 920c InkJet Printer
I have a phillips ipf525 could you show me how to set up
According to the user guide, the problem you're experiencing could be due to the following:
Print cartridge access door might be open.
• Close the access door.
Print cartridges might be missing or not installed properly.
• Re-insert the print cartridges and make sure they are properly seated.
There might be a problem with the print cartridge.
• Close the access door. If the light continues to blink, one of the print cartridges is defective.
Do the following:
1) Remove the black (or photo) print cartridge.
2) Close the access door.
If the "check print cartridge" light blinks, the tri-color print cartridge is defective and must be replaced.
If the light does not blink, the black (or photo cartridge) is defective.
In all probability, the contacts on the contact ribbon are not connecting properly. Take a common pencil eraser and rub lightly across the contacts on the ribbon to remove any contaminants or debris.
Check the contacts inside the cartridge carrier to ensure that they're not dirty, bent or broken.
You should also inspect the carrier itself. If the plastic frame is cracked or broken and the cartridge can wobble around, it will usually install without any trouble but when you close the access door the carriage immediately moves back into print-ready position. The cartridge will shift and break its' connection. This will cause these types of errors as well.
If it's cracked or broken, go and get a new printer.
Jun 13, 2010 | Office Equipment & Supplies
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Light blinking
did you clean the carriage contact,carriage is part of the printer where you insert the cartridge.If you replace both cartridge and still the problem occur, i think you have to open your printer,maybe there are some dirt's that cause by s mice or a cockroach.
Sep 09, 2009 | HP DeskJet 5150 InkJet Printer
I have and hpdeskjet 960c printer. The amber light over the symbol for the ink cartridges is blinking. I replaced both the black and color cartridges. The light is still blinking and the printer won't...
open the top cover and allow the print cradle to move to one of the icons this indicates what the problem might be
it either shows that the cartridge is not inserted properly or the incorrect cartridge
or may be low on ink.
remove the cartridge and reinsert
if all else fails replace with new cartridges
Oct 02, 2008 | Office Equipment & Supplies
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
HP DeskJet 952c InkJet Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
