Question about Metabo GE700 Grinder
Front bearing over heating. New bearings installed. Still over heating
How do I grease the wheels and what brand grease do I buy?
If you are repacking front wheel bearings on a car with disc brakes,you will want to buy wheel bearing grease suitable for the higher heat generated by the disc brakes.Any name brand wheel bearing grease will work as long as it is rated to be used on vehicles with disc brakes.
TIP: Do not wash the wheel bearings in solvent to clean them if they are in good shape and have no metallic particles in the existing grease.Just repack using the new grease to push the old grease out of the bearings.After wiping the hub clean add some clean grease evenly into the hub,install the repacked bearings and new seals and JUST SNUG the nut which adjusts the bearing and install a NEW cotter pin.
Apr 08, 2017 | Cars & Trucks
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
GE Dryer DBVH512EF0WW vibrates/shudders excessively. Particularly with the top on. I've replaced the front top bearing, drum slides and felt seal. What is my problem?
The only thing I can think of is if you have plastic inserts built into the drum then maybe you installed the wrong kit in the dryer.
Their are basically 2 styles of GE dryers. Those that have a steel drum and a bearing with glides on the front panel and those that have felt on the front panel and the plastic glides mounted in the drum itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 12, 2012 | GE DCVH515EFWW Electric Dryer
I need a diagram on f250 hd 4x4 front wheel bearing to replace them
1 Jack the front of the vehicle up and support with jack stands. Remove the front tires and the front brake calipers. Hang the calipers up or support them so they are not hanging by the brake hose, which could damage the hose.
2 Remove the caliper support, then remove the center bearing cover using the hammer and chisel. Tap it out easily so as not to bend it. Remove the cotter pin in the spindle.
3 Remove the large bearing retaining nut and grab the rotor with your hand and rock it forward just enough for the front bearing to fall out.
4 Put the large bearing retaining nut back on, but do not turn more than four or five threads. Grab the rotor with both hands at the 3 o'clock and the 9 o'clock position and pushing down slightly, pull the rotor off swiftly. This will remove the rear bearing and seal at the same time. The retaining nut will knock the bearing and seal out as you pull the rotor off. Remove the retaining nut.
5 Remove the inner races for the bearings using the hammer and chisel. Put the chisel on the top of the bearing race and hammer it down toward the floor and then turn the rotor over and do the other side the same way.
6 Install the new bearing races using the old races as a buffer or an installing tool. Lay the new race in the rotor and line it up to the recession and lay the old race upside down on the new one. Hit the old bearing with the hammer to drive the new bearing into the recess. Make sure you drive the new bearing all the way into its recess. Do the same for the other side.
7 Fill the palm of your hand with grease and push one bearing at a time into the grease and drag it across the hand so that the bearings get a full packing of grease. Install the large bearing first by dropping the bearing into it's race and then installing the seal with the hammer.
8 Install the rotor back onto spindle and hold it in place. While holding the rotor on the spindle with one hand install the front small wheel bearing followed by the large washer and the retaining nut. Tighten the retaining nut (use the crescent wrench) just enough so that there is no play felt. Tighten the nut another 90 degrees with the wrench and then rotate the rotor a couple of times. Back the nut off until it is loose then tighten just until you feel the friction of it tightening up again and stop right there. The bearing must be tight enough that there is no freeplay, but not so tight that the bearings will seize up when they heat up and expand.
9 Install the cotter pin and the bearing cup. Install the caliper support and the caliper. Do the other side the same way then install the tires.
Jul 02, 2011 | Ford F-250 Cars & Trucks
How do i pull the hub off my 2002 mazda , on drivers side front
REMOVAL & INSTALLATION Except Miata FRONT
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Steering knuckle from the vehicle
    • Inner oil seal from the knuckle
  3. Using Mazda Hub Puller tools 49 G033 102, 49 G033 104 and 49 G033 105, pull the front wheel hub from the knuckle assembly.
  4. Remove or disconnect the following:
    • Bearing inner race from the front wheel hub
    • Retaining ring from within the knuckle
    • Front wheel bearing from the knuckle, using the hub puller tools
    • Brake dust shield
  5. Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced. To install:
  6. Using Mazda Press tools 49 G033 107 and 49 H026 103, install a new dust shield cover assembly to the knuckle.
  7. Using the press tools, press a new wheel bearing into the knuckle assembly.
  8. Install or connect the following:
    • Wheel bearing retaining ring
    • New oil seal using Installation tool 49 V001 795
    • Front wheel hub using the Mazda press tools
REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
    • Rear wheels Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar) 7923mg87.gif
    • Brake drum, if equipped
    • Rear caliper and rotor assembly from the hub, if equipped
    • Hub dust cover
  3. Raise the staked portion of the hub retaining nut with a hammer and chisel.
    • Hub retaining nut and discard it
    • Hub and bearing assembly from the spindle Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle 7923mg86.gif
    To install:
  5. Install or connect the following:
    • Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
    • Stake the nut into the groove in the spindle
    • Dust cover
    • Assemble the brakes
    • Rear wheel
Jan 01, 2011 | 2002 Mazda Protege
Left front hub replacement 2WD.
2WD pickups don't have hubs. They have rotors with bearings. Once you have the brake assembly supported, remove nut from spindle. Be sure not to strip the threads on the spindle. Remove the front set of bearings and pull the rotor off. Remove the rear set of bearings. Be sure to pack greases into new bearings prior to installation. Insert new rear bearing into rotor and replace onto spindle. Insert new front bearing and washer and re-install nut. Tighten to recommended torque specs, grease fittings and replace brake assembly.
May 15, 2010 | 2005 Chevrolet Colorado
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
Front end bearings need to be replaced
Yes New bearing should do the trick
Sep 26, 2009 | 2000 GMC New Sierra 1500
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Metabo GE700 Grinder Logo
107 people viewed this question
Top Metabo Grinders Experts
Tom Chichester
bob walter
bob walter
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Metabo Grinder Expert? Answer questions, earn points and help others
