Question about Logitech Z320 2 Speakers
New logitech speakers Z320 plugged in but not recognized. No sound Please help
  • 54 Answers
SOURCE: Logitech S-220 Speakers
Hi cfbruce,
First, double check your startup/user's guide cd and retrace your steps just to rule out the small stuff, you know, jacks are in tight, if its a 5.1 surround system the center speaker may have an on/off volume knob. Your speakers may have a player utility that needs to be configured i.e your utility may be set to headphones. Select the configuration that most resembles your speaker setup i.e headphones, cpu 2 speaker, surround, 5.1 or 7.1 etc.. and last, but not least, make sure your system is not muted. This will drive you crazy if you don't know the system is muted.
I hope this helped a little, if not , hit me back, we have other options.
Thanks for using FixYa.com
Sincerly, cyyyd7
Posted on Oct 09, 2008
Benimur
  • 6966 Answers
SOURCE: my logitech R-20 speakers.
Hi again,
Appreciate your reply and the additional information and as initially stated nothing is wrong with the speakers (Logitech R-20)
When you installed a new hard drive and reinstalled Windows, most but not all the necessary drivers were loaded which we can assume included the sound device. Though Windows recognized that there is a multimedia audio controller, it has no knowledge of what type and therefore would not know which drivers are needed. What is needed therefore, is determine what is your specific multimedia audio controller, let Windows know about it and proceed to install appropriate drivers.
The easiest way to do this would be with the use of the recovery CD and/or drivers CD that came with your PC or motherboard. If you have such a CD, pop it in your CD tray and read the contents. One folder should say something like Audio, Multimedia or sound. Explore that folder and look for any setup.exe or allow Windows to auto install. The latter is done by opening your Device Manager, right click on the yellow marking and click Update driver. When asked for the location of drivers, browse/point to where you saw the Audio, Multimedia or sound folder is (in the CD).
If no CD came with the computer, you need to determine what specific motherboard you have. If you are somewhere in Australia, perhaps you can try Concorde Computers for the necessary identification and possible driver download. You can also get their contact information here.
If for some reason that would not work for you, you can get you PC's motherboard model on the initial powerup. The display would show something like Asus XYZ, Gigabyte ABC or Intel 123. Using that motherboard model number, you can proceed to the MB manufacturer's website and download appropriate drivers or post back here that we can further assist you.
Cheers.
Posted on Jan 21, 2008
whitebirch
  • 433 Answers
SOURCE: No sound from logitech X240 speakers
start with the easy stuff to miss...wired correctly, power on (green light on the right speaker) Do you have it plugged into the GREEN socket on the rear of you computer, Is there an X in the mute box, double click on the speaker and check, do you have a splat in sound codec or any other sound component Now are you running XP speaker in a Vista world. If you are cool up to this point, Update the drivers from logitech or Acer. Logitech says they are not compatible with Vista...that could be it...
hope something here helped and got you up and listening. please leave rating.
Posted on May 10, 2009
  • 51 Answers
SOURCE: How do i fix my logitech pc speakers? Help please... Sound messed
You could be overloading the speakers. Make sure you are running within the parameters of the output. These are only 70 watt max output, which means COMBINED the total output will ony be 70 watts. If you get them to oloud you will overload them and then yes, they will fade out, or even blow.
Posted on Jun 13, 2009
bronk50
  • 27725 Answers
SOURCE: Logitech LS21 speakers connected to
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 16, 2011
My right speaker has stopped working. Any work around this? by tearing it open?
Unlikely. Check the wiring and the plugs. If they are OK, then you will need to take them apart. The right one is the one that holds all the amplifier parts. The left one is just a speaker.
If you are in the market for new ones, I can recommend Bowers and Wilkins MM1s. They are pricey, but high quality, have a warranty and are repairable. I have been around the factory.
Logitech have support for your speakers here
Logitech Support
Nov 21, 2015 | Logitech Z320 Speaker System
Can you connect logitechz320 speakers to a tv and how
You can connect the speakers up to the headphone jack, if the tv has one. If not, you may be able to use a Y adapter from the tv's composite audio outputs (again, if it has them). The Y will be red and white connectors on one end and a 3.5 mm jack (female) on the other.
Sep 15, 2013 | Logitech Z320 Speaker System
Why wont my computer recognize my speakers? My computer is gateway with windows vista on it. In my device manager it has a caution sign but the logitech website says the speakers dont need drivers. Please...
Those speakers are meant to just plug into a sound card or onboard sound device or any sound device that has headphone jacks e.g. iPod. They don't provide feedback to the PC, so there is absolutely no need for drivers, which is why you don't see them in device manager. Think of them as a glorified pair of headphones.
Aug 12, 2011 | Logitech Spin 75 Computer Speakers
I just converted to windows 7 from xp and now i cant find my external x-320 logitech speakers
Ok, windows 7 may not have the driver you need .
Try this. 1. Go online and try searching for Windows 7 drivers for Logitech X-320 Computer Speakers.
or goto Control panel in windows. Click on Hardware and sound. Then you will see a list of items. click on manage Audio devices , this should tell you whether you need new drivers and if your speakers have been recognized..
Hope this helps.
Feb 21, 2011 | Logitech X-320 Computer Speakers
Logitech speakers not working no sound
Turn off the speakers. Restart the computer with the speakers off. Once fully booted turn on the speakers. I had this problem where with the speakers on when the computer was started the sound card was not even recognized. Loading drivers had no affect. Good luck.
Nov 16, 2010 | Logitech Z-10 Computer Speakers
I don't have any CD or Driver of Logitech R 10 Speakar, So please tell what can i do?
I can help you with your logitech R10 speaker problem.
The Logitech R10 speakers do not ship with drivers. Please refer to the R10 Speaker setup guide which you can download direct from Logitech.
Your sound card may require drivers to be re-installed. Check where your speakers are plugged into, (line level rather than speaker preferred) and check your Control Panel > Sounds settings to make sure it is not muted and selected correctly.
I hope that helps.
Aug 30, 2010 | Computers & Internet
What's the name of speaker conector of the HT Samsung HT-Z320
They are called composite video and audio connections. (RCA jack style)
May 29, 2010 | Samsung Audio Players & Recorders
I have logitech x 230 speakers. When i use my old computer i just plug them in and they work. i installed an additional OS to my old computer; windows xp professional. The speakers were not even recog
You may need to install the audio drivers for those systems. If the sound is built onto the mainboard, you'll need the motherboard model number to help locate the drivers online. You can look for them yourself through a search engine, or if you'd like, get back to me with the model numbers of the motherboards, and I will locate your drivers. The model number of the motherboard should be printed directly on the motherboard itself.
May 15, 2009 | Logitech X-230 Computer Speakers
Logitech x-540 speakers wont work??
unplugg your hdmi cable and use a regular monitor cable then plug your speakers in to your sound card
Feb 27, 2009 | Logitech X-540 Computer Speakers
No sound
check in your device manager that you have installed the driver successfully.
1st go to control panel
2nd click on system
3rd click on properties
4th...on device manager and select it and see the status!
Dec 08, 2007 | Logitech V20 Computer Speakers
Logitech Z320 2 Speakers Logo
478 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
