Question about Pondmaster Pump 190 Gph 10ft Cord
I have a pondmaster 190 and it is not pumping. It will put water half way up the pipe and then stop and the water level pretty much stays half way up What to do
  • 528 Answers
Try turning on the pump and feel if it is blowing the water back out somewhere. If it pushes water 1/2 way then stops, you're losing pressure somewhere and you need to determine where. It is also possible you may have a bad seal, but I kind of doubt that - if so then it wouldn't be able to push water at all.
Posted on Nov 07, 2010
400 washer spen cyccle stops at half way panel blinks it stop rols 3 seconds unlock door. Cloths still wet. An anser please . I put module already.
is the pump partially blocked? my machine sometimes lets a sock into the outer drum which then gets into drain pipe between pump and drum so pump runs but only half water gets out
May 28, 2015 | Washing Machines
Liberty Pumps Pro370 Basement Bathroom
At this point, opening the access cover is the last thing you do if it is below the water level in the pipes. Your system has a partial blockage in the pipes between the pump and external septic tanks or sewage dump site, that is the reason why when you use the plunger , half of the amount of waste water comes up to the sink and bathtub. You to open up your pipelines to remove blockage , probably tree roots in the pipes.
Dec 31, 2013 | Liberty Pumps PRO370-Series, P372LE51, 41...
Making humming noise, but not pumping water
Are trying to run a 50 hertz motor on a 60 hertz line?
Sep 03, 2013 | Pondmaster In-Pond Filter System Kit -...
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
I have put a new water pump on a el falcon the rubber seal that goes between the pump and the pipe wont stay in place the pipe its self has a flange area can someone please tell me if the seal gos in...
found out the pipe had two flanges now only has one the seal is suposed to seat in between both flanges but side nearer pump has gone carnt complain too much 456,000 ks is a good run
Jan 15, 2011 | Flotec 1 Hp Deep Well Pump
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
I have a saniflo macerator toilet system and when flushed, the pump does not immediately come on and the water level rises up pretty high. only then the pump comes on for a second or two but the bowl does...
Did you put an 1 1/2" vent pipe? It must be vented to the open air. Air must flow in and out of the vent pipe at all times so it can work properly. I had the same issue but after removing the cheater vent from the vent pipe it solved my problem. They do not recommend using an air admittance valve, cheater or mechanical vent on the vent pipe, as it only allows air to flow in or out.
Jun 09, 2010 | Saniflo SANIBEST Pump Macerator Grinder...
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Pondmaster Pump 190 Gph 10ft Cord Logo
133 people viewed this question
Top Pondmaster Garden Experts
roeb
john h
Marvin
Marvin
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
